What is the issue with calculating eigenvalues using rgg.f?
  • Thread starter Thread starter llello
    Eigenvalues
The discussion revolves around an issue encountered while using a routine from the netlib to calculate eigenvalues and eigenvectors of a matrix. The user attempted to apply the routine to a simple diagonal matrix but faced a segmentation fault error during execution. The code provided includes the definition of matrices and a call to the routine, but the problem was traced back to incorrectly passing a zero value into the subroutine. The issue was resolved by ensuring that variables defined as zero were correctly handled in the code, highlighting the importance of proper variable initialization in programming.
llello
Hey folks, I'm having an issue using a routine from the netlib that is supposed to calculate eigenvalues and eigenvectors. The canned routine can be found here:
http://www.netlib.org/seispack/rgg.f
I want to find the eigenvalues of a matrix (a more complex hamiltonian), so for my simple attempt to get this code to work, I input the diagonal matrix with 1 and 2 on the diagonals. So if everything worked fine, this canned routine should just spit out 1 and 2. So my issue comes in when I run this, it spits out a segmentation fault error and I can't sort out why it isn't working. Anyone have any insight into where I'm going wrong? My trial code is given below.
program trial
implicit none
double precision, allocatable, dimension(:,:) :: hamiltonian
double precision, allocatable, dimension(:,:) :: identity
double precision, allocatable, dimension(:) :: reigenval
double precision, allocatable, dimension(:) :: ieigenval
double precision, allocatable, dimension(:) :: denom
double precision, allocatable, dimension(:,:) :: eigenvec
double precision trueValue(100)
double precision answer, pos, xstep
integer i, j, m, n, k, gridsize
gridsize = 2
k = gridsize
allocate(hamiltonian(k,k),identity(k,k),reigenval(k),ieigenval(k),denom(k),eigenvec(k,k))
! makes the matrices
do i=1, gridsize
do j=1, gridsize
hamiltonian(i,j) = delta(i,j)*i
identity(i,j) = delta(i,j)
enddo
enddo
! calls the canned routine
call rgg(k,k,hamiltonian,identity,reigenval,ieigenval,denom,0,eigenvec,0)open (unit=15, file='eigenvalueSHO.txt', access='append', status='new')
do i=1, gridsize
write(15,*) i, reigenval(i)
enddoclose(unit=15)
deallocate(hamiltonian,identity,reigenval,ieigenval,denom,eigenvec)contains
! function to calculate kronecker delta
double precision function delta(m,n) result(answer)
integer, intent(in) :: m
integer, intent(in) :: n
if (m .eq. n) then
answer = 1.0
else
answer = 0.0
endif
end function delta
end program
Computer science news on Phys.org
Ok, solved the problem. It was really stupid too. I was throwing "0" into the subroutine but i had to define variables that are zero to put into the code. Rookie mistake.
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
26K
