Elastic And Inelastic Collision Questions
16 replies · 5K views · last reply
spikefreeman
Problem 1: The coefficient of restitution for steel colliding with steel is 0.95. If steel is dropped from a height ho above steel plate, to what height will the ball rebound.
Problem 2: in an elastic head on collision with a stationary target particle, a moving particle recoils of its incident speed. What is the ration of the particles masses (m/M)
1. v2-v1=-e(v2o-v1o)
v=sqrt(2gh)
2. mv= mv + MV
1. -e= (v2-v1)/(v2o-v1o)
-.95=(v2-v1)/(v2o-v1o)
From there I honestly have no clue what to do.
2. mv = m(-1/3V) +MV
4/3mv = MV
The book answer is 1/2, and I'm working with thirds? Should I be using a KE equation?
Any help is appreciated.
Part 1.
What do v1, v2, v10 and v20 represent? Can you find expressions for them?
Part 2.
What is (-1/3 V) ?
v1o and v2o are the speeds before the collision, v1o at the top and v2o at the bottom. v1 is speed after collision and v2 is speed at max height after collision. So v1o and v2 are zero, and v2o is sqrt(2gh). Is any of that right?
I'm not really sure what you mean by what is -1/3V. Its a negative velocity.
The speeds of what before and after the collision? In your particular problem, what is object 1 and what is object 2?
It is a negative velocity representing the velocity of what object? Why did you pick 1/3 as opposed to 1/5 or 1/7?
Object 1 is the ball and object 2 is the steel plate. But I have speeds all for object one.
O v1o
l
l
l
l
V v2o
The o at the top is the ball and the l and v are an arrow, then the dashes are the steel plate. Then the V1 and V2 are the coresponding speeds except after the collision on the way back up. That is how I understood the problem
For the second problem, the 1/3 is given as the recoiling speed of the moving particle.
O v1o
l
l
l
l
V v2o
You understood the problem correctly. I believe that in this problem you are to assume that the steel plate is (and remains) at rest on the floor. What does this mean for v20 and v2? Also, can you find an expression for v10?
There is nothing in the statement of the problem that indicates that. Can you post the statement exactly as it is given?
v1o = 0 right? because its dropped from rest.
That means that v2o = sqrt(2gh) and that v2 is 0 because it is the maximum of the bounce.
Problem 2, that was a typo. It recoils at 1/3 of the incident speed. Sorry about that.
No, no, no. As I said, the steel plate is and remains at rest on the floor. If object 2 is the steel plate then what should v20 and v2 be?
Also, v10 is the speed of the ball just before it hits the floor and v1 is its speed just after the collision. If you know v1, you can find how high the ball will rise.
Look in your textbook. It must have an expression giving the final velocities of two colliding masses in terms of their initial masses when the collision is elastic. Use that expression.
ok that makes more sense. So v2 and v2o are zero. so v1o = Sqrt(2gh) and v1 is solved using mv=mv?
No. You find v1 using the given coefficient of restitution.
kk, so i just v1o in set the v2 as zeroes and i should be able to find v1. Is that it?
For part two I will check in the book.,
Thanks for you help.
I am not sure what you mean by this so I cannot say that it is or isn't OK.
I meant to say, I plug v1 in as sqrt(2gh) and set the v2 as zeroes...
v10 = sqrt(2gh), not v1.
right, and then solve for v1, and then use mgh. Is that it?
