Elastic collision and kinetic energy problem?
6 replies · 9K views · last reply
LarryJ
The figure below shows a thin, uniform bar whose length is L and mass is M and a compact hard sphere whose mass is m. The system is supported by a frictionless horizontal surface. The sphere moves to the right with velocity , and strikes the bar at a distance 1/4L from the center of the bar. The collision is elastic, and following the collision the sphere is at rest. The rod is being rotated from its center. Find the value of the ratio m/M.
1/2mv^2=1/2Iω^2
I know the collision is elastic, so kinetic energy is conserved. But I don't know exactly how find which mass ratios will make the collision elastic. I think I know inertia (1/12MR^2). But I'm basically stuck from there.
Hi LarryJ! :smile:
(try using the X2 button just above the Reply box :wink:)
angular momentum is also conserved (in any collision, and about any point)
also, you are told that the bar rotates about its centre
so write out the equations for conservation of energy, and for conservation of angular momentum about the centre …
what do you get? :smile:​
Kinetic energy: 1/2mv2=1/2Iω2
Angular Momentum: (1/12MR2)(ω)= mv(1/4R)2
So do I set the equations equal to each other and then solve for M and m?
i'm not sure what you mean by "set the equations equal to each other",
but yes, you solve for m/M :smile:​
