Elastic collision with two masses and spring
The discussion centers on an elastic collision involving two blocks with masses m1=2.00kg and m2=5.00kg, where block 2 is attached to an ideal spring with a spring constant Ks=1.12 kN/m. The initial velocities are vi1=10.0 m/s for block 1 and v2i=3.00 m/s for block 2. The maximum compression of the spring is determined to be 0.267m, and the final speed of the masses after the collision is calculated, revealing that mass 1 comes to a stop while mass 2 moves at 6.57 m/s.
  • Understanding of elastic collisions and conservation of momentum
  • Familiarity with kinetic energy equations and potential energy in springs
  • Knowledge of basic mechanics principles, including forces and motion
  • Ability to solve equations involving multiple variables
  • Study the principles of conservation of momentum in elastic collisions
  • Learn how to derive and apply the equations for kinetic and potential energy
  • Explore examples of elastic collisions involving springs in physics textbooks
  • Investigate the effects of varying spring constants on collision outcomes
Students studying mechanics, physics educators, and anyone interested in understanding elastic collisions and energy conservation principles in a frictionless environment.
eventob
Had to translate the original problem statement in order to post it here; sorry about the grammar.
Block 1 has a mass m1=2.00kg, moving to the right (along the x-axis) with an initial velocity vi1=10.0 m/s. Block 2 has a mass m2=5.00kg and is moving in the same direction as block 1, with an initial velocity v2i = 3.00 m/s. The surface is frictionless.
Block 2 is equipped with an ideal spring with Ks=1.12 kN/m.
When the two blocks collide, the spring will first compress, then expand to it's equilibrium position. The masses will then move independently.
The compression of the springs will have it's greatest value when the masses are moving with uniform velocity.
The collision is elastic.
Find the maximum compression of the spring.
I know that when we model the collision as elastic, both the kinetic energy and the linear momentum of the system is preserved.
delta P=0
delta k = 0
Tried to use the formulas above, and solve the system of equations. The problem would be very easy to solve, without the spring.
Thanks in advance. :)
Hint: How fast are the masses moving when the spring is at maximum compression? How can you figure that out?
The masses will have the same velocity at the instant where the spring is at maximum compression? I guess I could use the formula for conservation of linear momentum
M1*V1i+M2*V2i=M2*V2f+M1*V1f
If I make the assumption that the speed of the masses is the final speed right after the collision, I'll end up with something like this:
M1*V1i+M2*V2i=(M1+M2)Vf
If the kinetic energy of the system is constant:
(1/2)*m1*v1f-(1/2)*m1v1i+(1/2)*m2*v2f-(1/2)*m2v2i+(1/2)kx^2=0
But I don't think the last equation is correct?
Thanks for helping me out. :)
Exactly! That's the key.
Right! Vf is the speed at the point of maximum compression.
You forgot to square the speeds in the KE terms: ½mv². Also, v1f = v2f = Vf.
If I use the first equation derived from the cinservation of linear momentum, could I solve for the spring compression like this:
Right before collision:
Emek_i=K1+K2+Us
Where K1 is the kinetic energy of mass 1, K2 is the kinetic energy if mass 2 and Us is the potential energy of the spring (which is zero for now)
Right after the collision:
Emek_f=K+Us
Where K is the compound kinetic energy of the two masses, and Us is the elastic energy stored in the spring (1/2 k*x^2) ?
Unfortunately, I don't have the answer to this problem, I got it from my mechanics professor today, It' not from the text-book, and I can't find any examples realting to it.
Edit: Didn't see your last answer before I posted. Thanks, think I managed to solve the problem now. Thanks. :D
You've got it exactly right.
Got a follow-up question. Just found the maximum compression of the spring to be 0.267m. In part b of the problem, I am supposed to figure out the final speed of the masses.
If you look at the attachement in the original post, there is two equations there. Is this just a simple substitution problem? When i substitute the numerical data into the equations, i get V1f= 0, and V2f=6.57 m/s.
My intuition tells me that mass 1 should accelerate in the negative direction, opposite of it's initial direction, due to the force excerted by the spring.
Yes, since they give you the formulas for the final speeds after an elastic collision. (Usually you need to derive those results, which is a pain.)
I didn't confirm your arithmetic, but I don't see any problems.
Your intuition is correct. Mass 1 started out with a speed of +10.0 m/s and it ends up with zero speed--sounds like a negative acceleration to me.
