Elastic recovery-can you just check if i've got it right
  • Thread starter Thread starter maha
    Elastic
The discussion focuses on calculating elastic recovery for a wire subjected to a tensile force beyond its yield point. The user correctly determines that elastic recovery can be calculated using the yield strength and modulus of elasticity, resulting in an elastic recovery of approximately 1.04 mm. It is clarified that the tensile force and tensile load are not needed for this calculation, as they pertain to the plastic deformation region. The importance of remaining within the elastic limit to avoid permanent deformation is emphasized. Overall, the calculations and reasoning presented are validated by other participants in the discussion.
maha
Hiya
Im doing material science as part of my dental technology course. I've got a question, and I'm fidning it hard to tackle.If anyone can help or set me in the right direction, i would be most grateful
Wire, of diameter 0.46 mm, length 100mm.it is subjected to tensile force of 2356 N, taking it beyond its yield point.
Calculate, in mm, the elastic recovery that would occur upon removal of the tensile load
Info given: Modulas of elasticity 67 GPa
Yield Strength 698 MPa
Tensile Strength 1379 MPa
okies, i think i got it. so, to calculate elastic recovery, i can only use the elastic range, so in order to work out elastic strain, i use yield strength/modulas of elasticiy. that gives me an answer of 1.041791045 N
Then, strain = extension/original, so to work out extension, i caluclate, strain x original length, which gives me 1.041791045 x 10-3 m
So answer is 1.04 mm of elastic recovery?
So then , i do not need to calulate the cross-sectional area or the stress value?
Can somebody just check this for me please :)
Didn't we have this discussion already? :smile:
Answer: Yes, it's correct!.
yes, but i wasnt sure if i was right that's why i posted it back up. How come the inforamtion of information of the tensile force and tensile load is not used. Is this because they are related to plastic part of the graph?
Thank you for your help :) hope i get the 4 marks
Because the elastic recovery will only be upto the Elastic limit, if it goes after such limit, there will be permanent deformations on the material, like i said on your other thread.
