Electric field from potential V = 1920x² between parallel plates
6 replies · 7K views · last reply
peaceinmideas
The electric potential V in the space between two flat parallel plates 1 and 2 is given (in volts) by V = 1920x^2, where x (in meters) is the perpendicular distance from plate 1. What is the magnitude and direction of the electric field at x = 2.5 cm? (Take the direction perpendicular to and away from plate 1 to be positive.)
E= V/r
First, I converted the cm to m, and then I plugged everything in, by saying: (1920*0.025^2)/0.025= 48.0. The answer is incorrect, also the negative of 48 is incorrect. I am not sure where to go from here and there was no picture to assist. Any help would be appreciated. Thanks.
The relevant equation given by you is true for uniform field. In the given problem field is not uniform. Potential is a function of x^2. In that case the eelctric field is given by
E = - dV/dx.
When I put in my numbers using that equation, I get the same thing: E= -dV/dx = - 1920*(.025 ^2)/ .025 = 48V/m. I may be mistaken though... any thoughts?
It is not correct.
E = -dV/dx = - 1920*d/dx(x^2).
What is the derivative of x^2?
Did you mean to say 1920*x/ dx? Then, I would get (1920*.025)/ (2*.025) = 960, does that sound correct?
No. d/dx(x^2) = 2x.
E = -dV/dx = - 2*1920*x
Oh, okay. Thanks a lot for all of your help. I am not that great at physics.
