Electric Field Zero: Charge Distribution on Y-Axis
  • Thread starter Thread starter MarkFL
The discussion focuses on determining the point along the y-axis where the electric field is zero due to two charges, $-q_1$ at the origin and $-q_2$ at $y=d$. The solution involves applying the principles of electrostatics, specifically the superposition of electric fields from point charges. The correct position for the zero electric field is derived through calculations that consider the distances from the charges and their magnitudes. Members kaliprasad and others successfully submitted their solutions using this method.
  • Understanding of electrostatics and electric fields
  • Familiarity with point charge interactions
  • Knowledge of vector addition in physics
  • Basic calculus for solving equations
  • Study the concept of electric field lines and their properties
  • Learn about the principle of superposition in electrostatics
  • Explore the mathematical derivation of electric fields from point charges
  • Investigate the effects of multiple charges on electric fields
Students of physics, educators teaching electrostatics, and anyone interested in solving problems related to electric fields and charge distributions.
MarkFL
MHB
Here is this week's POTW:
A charge $-q_1$ is located at the origin of a $y$-axis and a charge $-q_2$ is located at $y=d$. At what point along this axis is the electric field zero?
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct submission:
  • kaliprasad
My solution is as follows (kaliprasad used the same method):
Coulomb's law tells us that the magnitude of an electric field $E$ resulting from a point charge $q$ at a distance $r$ from the source is given by:
$$E=k_e\frac{|q|}{r^2}$$ where $k_e$ is Coulomb's constant.
We require the magnitude of the vector sum of the two fields along the $y$-axis to be zero at $d$. For like charges, this will only occur in between the charges ($0<y<d$), where the directions of the two fields point in opposite directions. And so, we require:
$$k_e\frac{q_1}{y^2}=k_e\frac{q_2}{(d-y)^2}$$
This results in the following quadratic in $y$:
$$\left(q_2-q_1\right)y^2+2dq_1y-d^2q_1=0$$
When $q_1=q_2$ we get the linear equation:
$$2dq_1y-d^2q_1=0\implies y=\frac{d}{2}$$
Otherwise, using the quadratic formula and discarding the negative root, we obtain:
$$y=\frac{-2dq_1+\sqrt{4d^2q_1^2+4\left(q_2-q_1\right)d^2q_1}}{2\left(q_2-q_1\right)}=\frac{-dq_1+d\sqrt{q_1q_2}}{q_2-q_1}=\frac{d\sqrt{q_1}\left(\sqrt{q_2}-\sqrt{q_1}\right)}{\left(\sqrt{q_2}+\sqrt{q_1}\right)\left(\sqrt{q_2}-\sqrt{q_1}\right)}=\frac{d}{1+\sqrt{\dfrac{q_2}{q_1}}}$$
