Electric motor efficiency and potential between parallel plates
  • Thread starter Aravsion
    Electricity
9 replies · 10K views · last reply
Aravsion
I have two problems that I have difficulty understanding and solving.
The operating efficiency of a 0.5 A, 120 V electric motor that lifts 9 kg mass agaisnt gravity at an average velocity of 0.5 m/s is most nearly what percentage?
Please help me solve this problem
2. Homework Statement
Two large, flat, parallel, conducting plates are 0.04 m apart, as shown in the picture. The lower plate is at a potential difference of 2 V with respect to ground. The upper plate is at a potential of 10 V with respect to ground. Point P is located 0.01 m above the lower plate. The electric potential at point P is? The magnitude of the electric field at point P is?
Diagram of two horizontal parallel plates: the upper plate labeled 10 V and the lower plate labeled 2 V, separated by a vertical arrow marked 0.04 m. Point P sits 0.01 m above the lower plate.
Please help me understand and solve this problem also...
Diagram of two horizontal parallel plates, the upper plate labelled 10 V and the lower plate labelled 2 V, separated by 0.04 m. A point P sits 0.01 m above the lower plate.
Welcome to the PF.
For (1), please list the equations for work (both mechanical and electrical). Please show your work.
For (2), please list the equations for the Electric field as a function of voltage and distance. Please show your work.
Welcome to the PF.
The equation for mechanical work is Work = force x distance and for electrical it's Potential difference (V) x q (charge) = Work or Potential energy difference of the charge... Is that what you're asking?
E = F/q and also E = V/d
For electrical work in this problem, you will use the motor's current and voltage to get the power, and you use time to convert power into work. What are the equations for that?
And then go ahead and describe how you would calculate the efficiency of the motor system in doing the mechanical work...
[tex]Power = UI[/tex] so the power of the motor is - [tex]Power = 120 \textup{ V}\times 0.5 \textup{ A}[/tex] and this equals to 60 watts. How can I find the time though?
Also, from lifting the 9 kg mass at a velocity of 0.5 m/s I can convert the 9 kg mass to its weight (9 kg * 9.8 m/s2) and then simply multiply that weight quantity by 0.5 m/s to find the power of that? In other words, [tex]Power = \frac{Work }{time} = Force \times \frac{distance}{time} = Force \times velocity[/tex]
But once again I need to find the time to find work... and then use the equation: [tex]Eff = \frac{Woutput}{Winput}\times 100[/tex]
If each of the powers are constant over time, and if work = power x time, then over any given time interval Δt:
[tex]\frac{W_{out}}{W_{in}} = \frac{P_{out} \times \Delta t}{P_{in} \times \Delta t} = \frac{P_{out}}{P_{in}}[/tex]
gneill
Thank you :) now I understand.. The answer I got was 75%...
Also, how would I approach the 2nd problem, do you have any ideas?
If you assume that the potential changes linearly with distance from 2V at the bottom plate to 10V at the upper plate, what is the potential at point P? Start by finding the total change in potential ΔP, and the total change in distance Δd. What ratios can you set up to relate the distance of P to the change in potential?
gneill
Big thanks! :smile:
I solved it like this, if my thinking was wrong please correct me:
[tex]8 \textup{ V} = 0.04 \textup{ m}[/tex] - This is because we know that the distance between the top and bottom plates is 0.04 meters and the difference in potential difference is 8 volts.
[tex]1 \textup{ V} = 0.005 \textup{ m}[/tex] - From this, we know that the bottom plate starts from 2 V and the potential difference starts escalating towards the top plate which has a voltage of 10 V. Thus, [tex]1 \textup{ V} = 0.005 \textup{ m}[/tex]
[tex]2 \textup{ V} = 0.01 \textup{ m}[/tex]
Therefore, the potential difference at point P is 4 V and the magnitude of the electric field would be - [tex]E = \frac{8 \textup{ V}}{0.04 \textup{ m}} ; E = 200 \textup{ V/m}[/tex]
