Electrical conductivity of liquid argon
The discussion centers on the electrical conductivity of liquid argon, particularly at low pressures (maximum 3 atm). Participants highlight the scarcity of studies focused on this specific condition, with most research addressing high-pressure scenarios. Key insights include the relationship between electrical conductivity and electron mobility, drift velocities, and the importance of free electron density. It is concluded that liquid argon behaves as an insulator under low-pressure conditions, with conductivity potentially increasing at higher pressures and temperatures, influenced by impurities present in the liquid.
  • Understanding of electron mobility and its relation to conductivity
  • Familiarity with the properties of liquid argon in particle physics
  • Knowledge of the effects of impurities on electrical properties
  • Basic principles of RF wave propagation in conductive materials
  • Research the relationship between electron mobility and conductivity in noble gases
  • Explore the effects of impurities on the electrical properties of liquid argon
  • Study the propagation of RF waves in liquid argon detectors
  • Investigate high-pressure studies of electrical conductivity in argon, krypton, and xenon
Researchers in particle physics, electrical engineers, and anyone studying the properties of noble gases in low-temperature applications.
doctor_cat
Dear friends,
does anyone know if there exists any study about electrical conductivity of liquid argon?
Thank you in advance for any suggestion.
Sorry, I forgot to specify I am interested in liquid argon at low pressure (maximum 3atm).
On Google, I found only studies about overpressured liquid argon (tens of MPa).
What exactly is your motivation or the application that prompts your question? I think liquid argon is, for all practical purpose, an insulator. It is used in particle physics experiments to detect high-energy particles. When a high energy particle makes a collision in the liquid argon, it creates free carriers which can be swept up and counted by a counter. So the stats on electron mobility, etc., refers to that application.
Electrical conductivity is related to the Electron Mobility:
https://en.wikipedia.org/wiki/Electron_mobility#Relation_to_conductivity
However, this contains an important variable: the electron density. This density is not the total density of electrons in the substance, but rather the density of "free" electrons. Neutral, low-temperature/pressure Argon will not have any free electrons.
That said, I did find this source, which measured the electrical conductivity of Argon, Krypton, and Xenon at high pressures (and presumably temperatures):
https://aip.scitation.org/doi/abs/10.1063/1.1303633
They do find some conductivity, but it's not a simple relation: the conductivity depends exponentially upon temperature within certain experimental regimes (this is expected for substances with no free electrons). I can't access the full paper, so I don't know the details.
My guess is that the answer is that the conductivity is zero at low temperatures, but it's possible for Argon to become conductive at high pressures and temperatures.
The aim is to study the propagation of RF waves in liquid argon detectors.
This might be useful:
https://arxiv.org/abs/1511.07724
Edit, just noticed the RF wave point:
I'm not sure the conductivity will be the most important factor in determining the attenuation of RF waves. The paper I linked above shows an experiment where they were testing for much higher-frequency signals (for the purpose of understanding how Cherenkov radiation travels through liquid argon), but as the attenuation drops off pretty sharply at lower frequencies in their test, my bet is that the attenuation will be effectively zero for RF waves.
Attenuation of RF waves in liquid Ar, if it is significant at any frequency, would likely be driven by complicated quantum effects (such as particular frequencies exciting certain resonant modes in the Ar fluid).
It should be like you guessed.
I will try to have access to the paper.
I think one issue is being overlooked here.
If the question is about real liquid argon I am pretty sure the RF properties (e.g. loss tangent) will be dominated not by the argon itself (which is presumably a very good insulator) but by the presence of various impurities.
This is certainly the case for most low-loss crystals such as sapphire (crystalline aluminium oxide) which "in theory" has loss tangent of something like 1e-11; but in reality you would be very lucky to find a real sample with a loss tangent lower than high 1e-7 (at low temperatures); the difference is simply due to presence of very low concentrations of various impurities (in sapphire ions.such as e.g. chromium and iron).
Granted, the effect of impurities will be different in a liquid; but I am pretty sure the basic principle still applies: the purity of the argon will be a crucial parameter
That's a very good point. As I understand it, pure water is a pretty good insulator. Nearly all of water's conductivity stems from impurities.
High power radio and radar transmitter tubes once used triple-distilled water as their cooling medium. Several are shown in a photo at the Museum of Radio and Technology website.
