- 42,843
- 10,509
Draw a vertical line down from the apex and consider the two triangles produced.sea333 said:I still don't see how this is correct as angle 10 is not adjacent to r
The discussion revolves around the forces acting on two balls hanging from a ceiling at an angle, specifically focusing on the relationship between electric force, tension, and gravitational force. Participants are exploring the balance of forces in both horizontal and vertical directions, as well as the implications of the angle formed by the strings.
The discussion is active, with participants providing guidance on how to set up equations and questioning assumptions made in earlier posts. There is an ongoing exploration of the relationships between different forces and the geometry of the setup, with no clear consensus reached yet.
Some participants note the need to use symbols instead of numerical values in their equations and emphasize the importance of correctly applying trigonometric relationships to the problem. There are also mentions of potential errors in previous attempts, particularly regarding the use of angles in calculations.
Dropping a perpendicular from the apex of an isosceles triangle to create two congruent right angled triangles is pretty basic geometry; less advanced, even, than the cosine rule.sea333 said:I don't think I will need these advance techniques in my exercises
I have checked this and I get r = 2a*sin10haruspex said:Dropping a perpendicular from the apex of an isosceles triangle to create two congruent right angled triangles is pretty basic geometry; less advanced, even, than the cosine rule.
Yes, as in my correction in post #27.sea333 said:I have checked this and I get r = 2a*sin10
1 - cos^2(10) + sin^2(10) = 2sin^10 because cos^2(10) + sin^2(10) = 1sea333 said:sqrt(4a^2sin^2(10)) = 2*a*sin10
How do you get from 1 - cos^2(10) - sin^2(10) to 2 sin^2(10) ?
