Electricity Question for Unit 2 Edexcel
gangnamstyle
If lightning strikes a tree such that there is the same current through it as there was through the lightning conductor, then a much larger potential difference exists between top and bottom of the tree. Explain why this is so.
Is this something got to do with area ? R=pl/A ?
How do you explain this ?
There are 3 variables there: ρ , l & A you should consider/compare each of them.
This is how I answered :
The tree has a smaller area. From the equation ( R=pl/A ), when A is small, resistance is higher because they're indirectly propotional to each other. From equation ( V= IR ), when R increases, p.d. increases.
Not sure whether correct or not. Otherwise, how would you answer it ?
I think the key is the ρ : the resistivity.
Most lightning conductors are small in cross-section, and made of brass or iron.
Most trees have a large cross-section, but are made of wood!
Also, a lightning conductor is long enough to reach from the ground to the top of a tall building [they don't use them on short buildings]. How tall [long] is a tree?
