Confused mind
I have encountered a problem that how electric and magnetic fields at perpendicular to each other are produce in electromagnetic radiations?
Electric and magnetic fields in electromagnetic radiation are produced perpendicularly to each other primarily in the 'far field' of a radiator, such as a simple antenna. Close to the antenna, fields can exhibit various angles due to the influence of different wave modes. In the standing wave region, fields result from multiple traveling waves, while waveguides can support TE modes in addition to the standard TEM mode found in coaxial cables. Understanding these principles is essential for grasping wave propagation and antenna behavior.
PREREQUISITESStudents and professionals in electrical engineering, physicists studying electromagnetic theory, and anyone involved in antenna design and wave propagation analysis.
This is only the case in the 'far field' of a radiator. Right up close, the fields can have a range of relative angles around, say, a simple antenna. It is only when the fields have settled down at a distance and there is only energy being transferred and not stored (as in a Capacitor or Inductor). A plane EM wave in space is the simplest case.Confused mind said:I have encountered a problem that how electric and magnetic fields at perpendicular to each other are produce in electromagnetic radiations?
sophiecentaur said:This is only the case in the 'far field' of a radiator. Right up close, the fields can have a range of relative angles around, say, a simple antenna.
It is when the only wave is a progressive wave. In the standing wave region the fields will be the resultant of various traveling waves in different directions. Also, in waveguides, not all the modes are TEM, there are TE modes too. Coax is always TEM, though.Drakkith said:Is that so? Huh. I never knew that. I thought the angle was always 90 degrees.
