Electromagnetic waves radiating away from a transmitting tower
DottZakapa
A radio station on the surface of the earth radiates a sinusoidal wave with an average total power of 50 kw. Assuming that the transmitter radiates equally in all the directions above the ground, at a distance of 100 km from the antenna (ε0 = 8.85 10-12 C2N-1m-2)
electromagnetic waves
Homework Statement: A radio station on the surface of the Earth radiates a sinusoidal wave with an average total power of 50 kw. Assuming that the transmitter radiates equally in all the directions above the ground, at a distance of 100 km from the antenna (ε0 = 8.85 10-12 C2N-1m-2)
Homework Equations: electromagnetic waves
I divide the power by the half sphere
50000/(4πr2/2)
In such way i get the intensity per surface unity right?
which is also equal to
I=cε0E2
Now, from this equation i solve for E if i want to get Emax right ?
In case i need Bmax i divide Emax by c
Is there any error ? because can't get the right result
50000m/((4πr2)/2)
That's the right approach (but I don't know what the "m" is for in your expression).
I=cε0E2
Where did you get that equation?
that equation comes from:
Equation for electromagnetic energy density: u = (1/2) epsilon_0 E^2 + (1/(2 mu_0)) B^2, where u is energy density, E is electric field and B is magnetic field.
total energy density
Equation: B = E/c = sqrt(ε0 μ0 E), relating magnetic field B, electric field E, speed of light c, permittivity ε0 and permeability μ0.
relation between E and B
Equation: u = (1/2) epsilon0 E^2 + (1/(2 mu0)) (sqrt(epsilon0 mu0) E)^2 = epsilon0 E^2, showing total energy density in terms of E.
Equation: S = (1/A)(dU/dt) = epsilon_0 c E^2, relating Poynting vector magnitude S to energy per unit area per unit time and electric field E.
energy flow per unit area per unit time
But i realized that this leads to instantaneous intensity, in order to get the average intensity , S must be divided by 2.
Doing so you get the average intensity,
Printed equations for the intensity of a sinusoidal wave in vacuum: I = S_av = E_max B_max / (2 mu_0) = E_max^2 / (2 mu_0 c), and = (1/2) sqrt(epsilon_0 / mu_0) E_max^2 = (1/2) epsilon_0 c E_max^2.
which leads to the correct result.
Thanks 👍 very kind.
Exactly. Good work!
