Electronics true or false questions
  • Thread starter Thread starter Femme_physics
    Electronics
4 replies · 4K views · last reply
Femme_physics
Can you help confirm whether my answers are correct or not?------------------------------
True or False (+answer must be explained)
Question #1:
Ripple is an alternative component of the DC component of an electrical signal
Answer #1: True. A period, accoriding to wiki, is "small unwanted residual periodic variation of the direct current (dc) output of a power supply which has been derived from an alternating current (ac) source."
Question #2:
The saturation current in a transistor is greater than the conductance current
Answer #2: Not true.
Saturation current = 0
So it can't be greater than the conductance current!
The conductance current is greater than the saturation current.
Question #3: The following amplification of the op-amp is
Af = 1 + R1/R2
http://img833.imageshack.us/img833/3954/noninvert.jpg
Answer #3: True.
Since what we have here is a non-inverting op-amp, that's its formula.
Question #4: The duty cycle of the repeating signal is 40%
http://img15.imageshack.us/img15/3328/dutyc.jpg
Answer #4: Not true. Duty cycle is measured when there is current, not when there isn't. Therefor, in this case, it's 60%.
6/10 x 100 = 60%
I'll give it a try! :smile:
Hope it helps.
Femme_physics said:
Question #1:
Good!
Femme_physics said:
Question #2:
I do not know what you mean by "conduction current"... :confused:
There's a couple of possibilities.
But saturation current is when the transistor is saturated with so much base current that it can't open any wider.
This is the highest current you can get...
Af = 1 + R1/R2
Answer #3: True.
It is *almost* the formula...
Can you spot the difference?
6/10 x 100 = 60%
Yep! :smile:
I'll give it a try!
Hope it helps.
You, always.
Oh, so my bad. Yes, I forgot...it's kinda in the word, "saturated". *smacks forehead*
So, saturated must always be the highest current, therefor it must be higher than the "conductance current" (It's just the direct translation from hebrew)EDIT: The translation may be "threshold current", am not sure.
Yes, R1 an R2 are opposite in this case. Got it. Thanks! :smile:
Glad I got the other 2 right!
So it's all good now! ;)
Threshold current sounds a bit like cutoff current.
Remember that that was the opposite from saturation?
From wikipedia:
wikipedia said:
Cutoff: In cutoff, biasing conditions opposite of saturation are present. There is very little current, which corresponds to a logical "off", or an open switch.
