Electroplating from tungsten via phosphate salt?
The discussion centers on the electroplating of tungsten using phosphate salts, specifically phosphoric acid (H3PO4). Tungsten exhibits high resistance to diluted phosphoric acid in the absence of air but dissolves in concentrated acid. The proposed reaction involves tungsten and phosphoric acid forming tungsten phosphate, likely W(PO4)2, due to tungsten's oxidation states. The conversation highlights the lack of information regarding tungsten compounds and their suitability for electroplating, referencing sections 3.7 and 3.8 of "Tungsten: Properties, Chemistry, Technology of the Elements, Alloys, and Chemical Compounds" by Lassner and Schubert.
  • Understanding of phosphoric acid (H3PO4) and its properties
  • Knowledge of tungsten oxidation states and chemical behavior
  • Familiarity with electroplating processes and techniques
  • Basic concepts of metal ion electrode systems and their irreversibility
  • Research the electroplating process of tungsten using phosphoric acid
  • Investigate the properties and applications of tungsten phosphate compounds
  • Learn about the electrochemical behavior of tungsten in various oxidation states
  • Explore the implications of metal/metal oxide/metal ion systems in electroplating
This discussion is beneficial for materials scientists, electrochemists, and engineers involved in metal finishing and electroplating processes, particularly those focusing on tungsten and its compounds.
jrodatus
At the bottom of page 54 of Tungsten: Properties, Chemistry, Technology of the Elements, Alloys, and Chemical Compounds by Lassner and Schubert:
Phosphoric acid (H3PO4): Tungsten is highly resistant to diluted phosphoric acid as long as air is excluded. It dissolves easily in concentrated acid.
I'm presuming the reaction goes something like 2H_{3}PO_{4} + 2W → 3H_{2} + 2WPO_{4}
Since I'm pretty sure copper phosphate works just fine for electroplating, why wouldn't tungsten phosphate? What's the difference? The absence of any Google info on this makes me think there must be some good reason why it won't work.
But it sure would be useful for a particular project. Would appreciate input!
Chemistry news on Phys.org
I think the result is more like W(PO4)2, since phosphate is -3 while W can be +6. Since tungsten has several oxidation states running from +6 to -2, there may be different compositions.
Okay, assuming W loses all 6 electrons like it can, that sounds like a pretty strong bond. I suppose it would be insoluble in pretty much anything. Thank you.
Sections 3.7 and 3.8 of your reference also discuss some aspects of electroplating with tungsten. Apparently, not much is known about tungsten compounds and this lack of information makes it difficult to determine which compounds are the most suitable.
Doh, thank you again. From page 123:
In aqueous solution, no oxygen-free tungsten cation exists but only monomeric or dimeric species like WO^{2+}_{2}. Tungsten, due to its great affinity to oxygen, may never form a metal/metal ion electrode system but always a metal/metal oxide/metal ion system, which is quite irreversible.
(Just posting it here for reference. Hope that's not a copyright violation.)
Nope. You aren't claiming the work is your own, and it falls under what is known as 'fair use'.
