Electrostatic force between more than 2 charges
16 replies · 13K views
moonlight13
hi
i don't know if this has been posted or not but i am sort fo stuck on this one
What is the force F_vec on the 1 nC charge at the bottom? View Figure
Write your answer as two vector components, separated by a comma. Express each component numerically, in Newtons, to three significant figures.
the figure looks like this
attempt to this problem:
i found out the forces individually and added them together .. but it didnt work
x-component:
6nC = 0
2nC = 5.09 x 10[tex]^{-5}[/tex] each
y-component:
6nC = 2.16 x 10[tex]^{-5}[/tex]
2nc = 5.09 x 10[tex]^{-5}[/tex] each
when i add them: 1.02 x 10 [tex]^{-5}[/tex] [tex]\hat{x}[/tex] , 7.76 x 10[tex]^{-5}[/tex] [tex]\hat{y}[/tex]
but that was wrong.. i also tried the x-comp to be 0 .. but that was wrong too
thanx in advance for the help
How does the x-component of the force exerted by one 2 nC charge compare to that of the other?
they are opposite of each other .. which means there is no net x- component .. but that's not the right answer tho..
moonlight13 said:
hi
the figure looks like this View attachment 12308
x-component:
6nC = 0
y-component:
I see 2 things you might do differently to help.
Make sure you're doing vectors (right is +, up is +). Keep the vector notation throughout.
Check your use of scientific notation. If you're unsure, have your calculator switch it to regular decimal.
i tried a similar question, with 1 + and 1 - 2nC charge .. and that worked out
but somehow i can't get this working ..
i am not too sure if the y - component it right as well or not .. even tho it seems right
Show how you calculated the vertical components of the forces from the 2 nC charges.
moonlight13 said:
y-component:
What are the directions (signs) of these components?
y-comp = Esin[tex]\vartheta[/tex]
r= 5x10^-2
E = Kq[tex]_{1}[/tex]q[tex]_{2}[/tex] / r[tex]^{2}[/tex]
= (9.0x10^9)(2x10^-9)(1x10^-9)/ ( 2.5x10^-3)
E= 7.2x10^-6
y-comp = E sin(45) = 5.09x10^-6
6nC = +y, no x
2nC = +y, +x (on the right)
2nC = +y, -x (on the left)
and that's why my understand was that the x components would cancel out .. but i am not sure what's going on
moonlight13 said:
6nC = +y, no x
Realize that the 2 nC charges are positive and the 6 nC charge is negative. Which way do their forces on the + 1 nC charge act?
so the 2 +y .. should be -y ..?
i did the calc again and i get
x = 0
y = 1.14x10^-5 ..
doe sthat seem right?
Correct. Since the charges repel, the y component of force is downward and thus negative.
thank you ., thank you ... thank you..
r= 5x10^-2
E= 7.2x10^-6
What's the distance between the charges?
x = 0
y = 1.14x10^-5 ..
what you said abt the charges repelling .. this answer is right ..
thank you so much once again
You are most welcome.
Never mind. You had written the distance squared. :smile:
