Elementary proof of Fermat's Last Theorem using digit analysis
  • Context: Graduate
  • Thread starter Thread starter Victor Sorokine
    Proof Theorem
150 replies · 35K views
ramsey2879 said:
Your proof is lacking too much detail.
For ramsey2879 and Hurkyl
Completion of the Impromptu-proof
Here is complete algorithm of the proof (in base 7):
0. b < a < c.
1. Transform the number u/u^k into u_{n^s} – 1 with result 666…666 (cf. Lemma 3);
2. Multiply u_{n^s} – 1 by n – 2 with result 566…662
and after multiply by u^k with result 566…661000…00 (s + 1 + k = t digits).
I. If c = c_(s+1+k), then 1° has no solution (2 examples):
6…^n + 5…^n >> 6…^n; 7…^n + 2…^n >> 2…^n.
II. c > c_(s+1+k). Let maximum number (or rank) of digits in a, b, c is equal to r. For r-th digits we have: a_{r} + b_{r} – c_{r} = 0!
Then 1° has no solution (2 examples ):
2…^n + 3…^n << 5…^n; 10…^n + 11…^n << 2…^n.
To be continued
VS - 2005.08.08
Thanks
If the contradiction there is not in the last digits then it exists in the first...
If the contradiction there is not in the last digits then it exists in the first digits!
About the Proof-2
From (1°) it follows:
u (= a + b – c) > 0; (c – u)/u < 2/n.
Example for n = 5.
If c is given then max(a + b) reaches by a = c, from here 2a^5 = c^5, from here 1.1487f = c, from here a = 0.87055;
u = (2 x 0.87055 – 1)c = 0.7411; c = 1.349u = u + 0.349u.
Let r is maximum rank of number u. Then 0.349u = 0.349(u_(r – 1) + n^(r – 1)u_r) < 0.349(n^(r – 1) + n^(r – 1)u_r) =
= 0.349 n^(r – 1)(u_r + 1) = n^(r – 1)(0.349 (u_r + 1)) < n^(r – 1)(0.349n)). Therefore (c – u)_r < 0.349n = 0.349 x 5 = 1.75.
Always max(c – u)_r = 1.
And always (a – a_(r)) + (b – b_(r)) – (c – c_(r)) ==0 (2°).
Lemma
For any integer a (where a_1 =/ 0) there are such p and m that ap = n^m – 1.
Truth of the Lemma follows from Little Fermat’s theorem: any prime number g1 is a factor of the number n^(g1 – 1) – 1,
and n^(g1 х g2 х… gt – 1) – 1 divides by g1 х g2 х… gt.
After multiplication of 1° by p^n and hence of the number u by p we turn the number u/u^k into n^m – 1
which consists (except k-ending) only of digits n – 1.
Proof of FLT has 2 cases.
Case 1: (abc)_1 =/ 0
If s = r impossibility of solution of 1° is obvious: even in favorable case a^n + b^n >> c^n.
2 examples in base 7: 6…^n + 6…^n > 6…^n; 5…^n + 5…^n >> 4…^n.
If s = r + 1 then or c_r < n – 1 and inequality a^n + b^n >> c^n conserves,
either c_r = n – 1 and then c_{r + 1} = 1 and (a – a_(r)) + (b – b_(r)) – (a – a_(r)) =/ 0 – cf. (2°).
Case 2: b = b'n^k, (ac)_1 =/ 0 (or c = c'n^k, (ab)_1 =/ 0)
This case is proved analogously, but here u = a + b'n^(kn – 1) – c
(since the number c – a contains a factor n^(kn – 1) – cf. ADDENDUM to Proof-1).
So 1° has no positive solution.
The proof is done.
11 August 2005
Commenting on Hurkyl's early solution set a = 3333333
b = 7114C11 c = 4444444. Now since -1=...CCCCCCCC indefinitively in P-adic with P=13, -1/12 =...1111111, so that we easily arrive at -1/4=...3333333, and -1/3 =...44444444.
However a infinitive series for b, base 13, that I do not know, but using computer program Pari, I was able to find (-1/3)^13-(-1/4)^13 O(13^13),and take the 13th root, which gives:61217114C11, O(13^12), which gives the correct solution 0 to O(13^12), or if you like in p-adic: (-1/4)^13+(61217114C11)^13-(-1/3)^13 =5*13^13+13^14+O(13^15).
This can all be transformed into the base 10 by observing the geometric series 1+p+p^2+++=[(P^n)-1]/(p-1), and thus for Order 13^12, we have:
{(13^12-1)/4}^13+839483858773^13-{(13^12-1)/3)^13 =5*13^13+13^14+O(13^15), or that 13^12 divides the expression, giving 12 right hand zeros in base 13.
So we have results as whole numbers and the suggestion this process can be extended, if we seek an even larger solution. (Note, Hurkyl has previously gone into a method for a larger solution.)
FLT-2005. Theses
The proof contains 3 tools only:
1) Scale of notation in base prime;
2) Lemma: for number a (there last digit a_1 =/ 0) there are such d and s, that ad = n^s – 1 (corollary from Little Fermat's theorem). After multiplication u (= a + b – c) by p in new Fermat's equation the number u has the form (in base 7): 666…666000…000 with r digits equal to n – 1 or "9" (with k zeros in the end; r > k + 2).
3) The number h = (c – u)/u > 0.
From c > a and c > b we have: 2c > a + b, c > a + b – c, c – u > 0, h > 0.
THE PROOF of FLT
1. Let a^n + b^n – c^n = 0 (1°).
2. For any rank i, where k < i < r, it fulfils the equality: a_i + b_i – c_i = 0, and for rank r this equality has a form:
(a_r + b_r – c_r)_1 = n – 1 = «9».
Case 1. c_r = n – 1 (= "9") and c_t = 0, where t > r; then a_r = b_r = c_r = n – 1 (= "9") and
even in the best case { if a = [(n^k)n^(r + 1 – k) – 1)], b = [(n^k)n^(r + 1 – k) – 1)], c = n^(r + 1) – 1} a^n + b^n > c^n:
[(n^k)n^(r + 1 – k) – 1)]^n + [(n^k)n^(r + 1 – k) – 1)]^n > (n^(r + 1) – 1)^n (2°).
Case 2. c_r =/ n – 1 (= "9") and therefore there is c_t =/ 0, where t > r.
Then even in the best case {if a = n^(r + 1) – 1, b = 1, c = n^(r + 1) + 1} a^n + b^n < c^n:
(n^(r + 1) – 1)^n + 1^n < (n^(r + 1))^n (3°).
Therefore the equation (1°) has no integer solution.
Next materials: detailing and numerical examples.
THE PROOF of FLT
{snip}
I don't think you have a proof of statement 2 above, i.e. that there are no carries in the addition of a and b or borrows in the substraction of c from a+b
Victor Sorokine
And judging from ramsey2879, I conjucture that this example may have a bearing on the problem:
[tex]35^2+612^2=613^2[/tex]
X+Y-Z=35+612-613 = 34, which in base 2 is: 100010, and multiplying by 2 gives us 1000100, which after a series of 0 gives us p-1=1, and then a new series of 0.
Condition at present
The last and first digits do not show the contradiction. The Lemma is necessaries but it do not work with the number u. THEREFORE the contradiction exists in middle digits and the Lemma works with the number c:
1. We transform number u into c = n^t – 1, or с = 999…999 [or: c = n^s(n^t – 1) = 999…999000…000]. Here 9 = n – 1, 8 = n – 2; maximal rank R of c R(c) = t.
2. If a = 8… and b = 8… then 8…^n + 8…^n < 9…^n. Here R(a) = R(b) = R(c) = t.
Therefore a_t = c_t = 9.
3. If b_t = 1 then 9000…^n + 1000…^n > 9999…^n and a^n + b^n – c^n =/ 0.
4. If a_{t – 1} = 8 and 98…^n + b^n = 99…^n then R(b) > t – 1 (cf. binomial theorem for n prim) and therefore (cf. point 3) a^n + b^n – c^n =/ 0. Therefore a_{t – 1} = 9.
Etc. to a_1. THEREFORE a = c and b = 0 < 1 and a^n + b^n – c^n =/ 0 for (a, b, c) > 0.
The cause of impossibility of the Fermat's equation is cleared from next equation:
(n^t + n^r)^n – b^n = (n^t)^n, where r < t and b is true number.
Example: c = 1010, a = 1000, 1010^n – b^n = 1000^n. From here 1010^n –1000^n = b^n or (1000 + 10)^n –1000^n = b^n or 1000^n + n10x1000^(n – 1) + d – 1000^n = b^n or
b^n = n10x1000^(n – 1) + d = n^(2 + 3n – 3) + d = n^(3n – 1) + d from here b > n^[(3n – 1)/n] or (in the worst case n = 3) b > n^3.
Conclusion: the increase of the digit c_r by 1 is impossible to compensate by subtract any (r-digit number)^n!
Now the proof with c = 999…999(000…000) is obvious.
Dear Hurkyl, Robert Ihnot and Ramsay2879,
thank you very much for your help.
Excuse me for unliterary and short texts.
Eight months have passed since the first time when an elementary proof of FLT was found, laid down and proposed to the attention of 70 mathematicians (they have asked for it; most of them are specialized in numbers theory). About 1,000 individuals visited internet sites with the text of the proof. However, no positive nor negative opinions have been expressed so far.
The idea of the elementary proof of the Fermat’s Last Theorem (FLT) proposed to the reader, is extremely simple:
After splitting the numbers a, b, c into pairs of sums, then grouping them in two sums U' and U'' and multiplying the equation a^n + b^n – c^n = 0 by 11^n (i.e. 11 power n, and the numbers a, b, c by 11), the (k+3)-th digit from the right in the number a^n + b^n – c^n (where k is the number of zeroes at the end of the number a + b – c) is not equal to 0 (the numbers U' and U'' are “multiplied” in a different way!). In order to understand the proof, you only need to know the Newton Binomial, the simplest formulation of the Fermat’s Little Theorem (included here), the definition of the prime number, how to add numbers and multiplication of a two-digit number by 11. That’s ALL! The main (and the toughest) task is not to mess up with a dozen of numbers symbolized by letters.
The redaction of the text dates of June 1, 2005 (after a discussion on the Faculty of Mathematics of Moscow University site).
The texts of the proof can be found on following sites:
English version of the demonstration (4kb): Revista Foaie Matematică: www.fmatem.moldnet.md/1_(v_sor_05).htm
Russin version in pdf : http://fox.ivlim.ru/docs/sorokine/vtf.pdf
FORUMS (Russian-language):
http://lib.mexmat.ru/forum/viewforum.php?f=1&sid=3fefd56c6fe2fa0e361464672ea92292 ;
http://forum.dubinushka.ru/index.php?showforum=40 ; http://www.scientific.ru/dforum/altern - page 7.
Victor Sorokine hi
I notice here about your paper only yesterday.
Do you know about this work on FLT in : www.fermatproof.com ?
Are you sure that A.Willes really know about your nice work to solve FLT ?
In any case I plane to study your sort mostly claim for the prove.
Thank you
Moshe
2) Lemma: for number a (there last digit a_1 =/ 0) there are such d and s, that ad = n^s – 1 (corollary from Little Fermat's theorem). After multiplication u (= a + b – c) by p {sic"d"} in new Fermat's equation the number u has the form (in base 7): 666…666000…000 with r digits equal to n – 1 or "9" (with k zeros in the end; r > k + 2).
It is possible to choose a "d" where ad = n^s-1 but r < k+2. If this is the case, then, for instance if r=2 then d must be multiplied by 10101...01 where the number of zeros between the 1's = r-1 to get a new R. It thus is possible to chose a "d" such that R > is any multiple of r > k+2.
THE PROOF of FLT
statement 2 is false
let a= 251, b = 326502, c=53 base 7
Then a+b-c=330000; thus d = 2020202 and k=4, r=8
A= 2020202*a=540404032, B=2020202*b= 666266660004, C=2*c=140404036
You state that for k<i<r [i.e. 4<i<8] that A_i + B_i + C_i =0, but this is false.
You should use variables consistently and watch your statements. Also please do not make us have to refer to your earlier proof to understand what you are talking about in the current proof.
but this is false.
Hi ramsey2879
thank you for your complicate example
You probably mean A_i+B_i - C_i = 0
let's see Victor replay to your contra example
But Isn't Victor FLT contradiction (?) appear only at the base n
which is the power of the original equation a^n+b^n=c^n.
Moshe
There is a question: is it THE END?
Dear ramsey2879, Hurkyl, robert Ihnot, learningphysics and moshek,
there is a question: is it THE END:
Start-situation:
u = a + b – c with k-zero-ending (k > 0);
r – maximum rank of c^n (1a°);
PROOF
1. Let’s multiply the equation (1°) by dn , where d = 1 + gn^r, in order to transform the digit
u_{r + k + 1} into 1 (2°). (The digits of u_(r + k) do not change.)
2. Now from
[a_(r + k) + a_{r + k + 1}]^n + [b_(r + k) + b_{r + k + 1}]^n + [c_(r + k) + c_{r + k + 1}]^n = 0 we have:
{[a_(r + k)] _(r + k + 1) + [b_(r + k)] _(r + k + 1) – [c_(r + k)] _(r + k + 1)} +
+ (n^(r + k + 2))(a_{r + k + 1} x 1 + b_{r + k + 1} x 1 – c_{r + k + 1} x 1) + (n^(r + k + 3))P = 0, where
{[a_(r + k)] _(r + k + 1) + [b_(r + k)] _(r + k + 1) – [c_(r + k)] _(r + k + 1)} = 0 (cf. 1a°) and
(a_{r + k + 1} x 1 + b_{r + k + 1} x 1 – c_{r + k + 1} x 1)_1 = u_{r + k + 1}.
From here u_{r + k + 1} = 0, that contradicts to (2°).
The proof is done.
Victor Sorokine
So? All you need to do is to (correctly) derive one contradiction in order to prove that one of your original assumptions must be false.
Do you think, that Victor prove for FLT is wrong ?
Moshe Klein
Start-situation:
PROOF
2. Now from
The proof is done.
Victor Sorokine
hi victor
well, even A.willes had a mistak in FLT until he fix it ( I hope)
Are all these calculation are in base n ?
Thank you
Moshe Klein
ramsey2879 hi
I am still study victor work on FLT , I know that it is Organic and very nice but I don't have a final opinion if it is really correct with no mistakes.
Does post 71 answer to your claim that statement 2 is palse ?
Thank you
Moshe Klein
The same idea, BUT…
Dear Moshe,
thank you and excuse my mistake.
There is interesting correction.
It is obvious:
If a^n + b^n – c^n = 0 (1°), then there is such s, that
/(a + n^(–s))^n + (a + n^(–s))^n – (a + n^(–s))^n/ < n^(–sn) (2°), where s > r + 1 and r is maximum rank of the number c, and
/(an^s + 1)^n + (bn^s + 1)^n – (cn^s + 1)^n/ < 1 (3°).
From here: n^sn(a^n + b^n – c^n) = 0, nn^[s(n – 1)](a^(n – 1) + b^n(n – 1) – c^n(n – 1)) = 0
{or a^(n – 1) + b^(n – 1) – c^(n – 1) = 0}, … a + b – c = n^(–s) 0, that is impossible.
V.S.
Dear Victor,
I am really like your non conventual's way of thinking. for the first time I find real interest in FLT because of your organic attitude that can explain ( I hope so ) why Fermat wrote what he wrote about this problem ! if your prove is right [ I don't know that yet ] you should present it at the icm exactly 365 day's from today .
Please look at http://www.icm2006.org/
I hope to have my final opinion about your nice work at October
but since you correct it already few times in this thread ( and that's fine )can you sent here the most update version of your work.
Thank you
Moshe
Error Of Principle Of My Critics
Counter-examples are done for such u where u'_{k + 1} = 0.
But in my published proof u'_{k + 1} =/ 0.(Not infrequently, to find the error in a counter-example it is more difficult then to solve the same problem.)
For 10 months 70 mathematicians (members of AMS) and
2000 amateurs could not find an error of principle in the demonstration.
I terminate the participation in the discussion about all following proofs.
So the discussion about the original proof continues.
A key of the proof:
For a and b:
if a + b = (a + b)_(k) = 0, then (a^n + b^n)_(k + 1) = 0,
if a + b = (a + b)_(k) =/ 0, then (a^n + b^n)_(k + 1) =/ 0 (cf. ADDENDUM).
For a, b, c:
if a + b – c = (a + b – c)_(k) = 0, then (a^n + b^n – c^n)_(k + 1) = 0 (cf. counter-examples),
if a + b – c = (a + b – c)_(k) =/ 0, then (a^n + b^n – c^n)_(k + 1) =/ 0 (cf. my proof).
Publications of the proof:
doc: Revista Foaie Matematică: www.fmatem.moldnet.md/1_(v_sor_05).htm
pdf: http://fox.ivlim.ru/docs/sorokine/flt.pdf
Correction in (9°) (cf. the proof):
(9°) u''_{k+2} = [v + (a_(k+1) + b_(k+1) – c_(k+1))_ {k+2}]_1.
Cause of the error: erroneous copying.
Victor
Don't confuse "could not find an error" with "didn't bother looking for an error". Most people don't bother trying to fill in the gaps of an argument for which they have little to no expectation of validity.
The problem is that you don't actually write a proof: you write a bunch of equations, occasionally with a brief comment, and very few, if any, are self-evident.
Don't forget the story of Ramanujan who could not prove his 4000 amassing results. [ few of them are wrong ] Victor have a new interesting vision about FLT and he may need the help and the giddiness of the 'expert' to expand / check / correct / or maybe unfortunately cancel his attitude.
please read the strange situation Perelman paper on Poincaré conjecture : ( was taken from www.mathworld.com )
The Clay Mathematics Institute included the conjecture on its list of $1 million prize problems. In April 2002, M. J. Dunwoody produced a five-page paper that purports to prove the conjecture. However, Dunwoody's manuscript was quickly found to be fundamentally flawed (Weisstein 2002). A much more promising result has been reported by Perelman (2002, 2003; Robinson 2003). Perelman's work appears to establish a more general result known as the Thurston's geometrization conjecture, from which the Poincaré conjecture immediately follows (Weisstein 2003). Mathematicians familiar with Perelman's work describe it as well thought-out and expect that it will be difficult to locate any substantial mistakes (Robinson 2003, Collins 2004). In fact, Collins (2004) goes so far as to state, "everyone expects [that] Perelman's proof is correct."
And also from there about the strange situation Mihailescu paper on the Catalan problem:
..Finally, on April 18, 2002, Mihailescu sent a manuscript purporting to prove the entire conjecture to several mathematicians. The paper was apparently also accompanied by an expository paper by colleague Yuri Bilu that analyzes and summarizes Mihailescu's argument (van der Poorten 2002).
So I think that Victor ask for meangfull interaction with his work, I will try my best to have my final opinion on his work on FLT until October.
Moshe
The simplest case for analysis
The simplest case for analysis: u_{k + 1} = u'_{k + 1} + u''_{k + 1} = 1
If u'_{k + 1} = 1, then u''_{k + 1} = 0, U'_{k + 2} =/ 0 (?), U''_{k + 2} = 0 and U' + U'' =/ 0;
if u''_{k + 1} = 1, then u'_{k + 1} = 0, U'_{k + 2} = 0 (?), U''_{k + 2} =/ 0 and U' + U'' =/ 0.
I highly doubt that: as I told Victor, don't confuse "did not prove" with "cannot prove". Remember that many of his 4000 amazing results were in his private notebooks, not in papers he was trying to publish, so there wasn't any real reason to give a rigorous proof.
And mathematicians have not described Victor's paper as "well thought out", and have not stated they expect it to be correct, so I don't see your point. It sounds like Perelman actually tried to write a proof, rather than an outline he claims to work, as Victor has done.
And I have no idea what point you're trying to make with this one.
Specially for MocheK
(1°) Let (an^t)^n + (bn^t)^n – (cn^t)^n = 0, where t >> maximum rank R(c) = r.
From here
(2°) n^r > (an^t)^(n – 1) + (bn^t)^ (n – 1) – (cn^t)^ (n – 1) > 0,
and
(3°) (an^t + 1)^n + (bn^t + 1)^n – (cn^t + 1)^n > 0 and hence
(4°) (an^t + e)^n + (bn^t + 1)^n – (cn^t + 1)^n = 0, where e < 1.
From (4°) we have:
(5°) n^t(a^n + b^n – c^n) + n^[t(n – 1) + 1][a^(n – 1) + b^(n – 1) – c^(n – 1)e] + P = 0,
where P < n^[t(n – 2) + r] << n^[t(n – 1) + 1].
From (5°) we have: [a^(n – 1) + b^(n – 1)]_(t) = [c^(n – 1)e]_(t), or
(6°) a^(n – 1) + b^(n – 1) = c^(n – 1)e.
But it's easy to show that it is impossible!
Victor
Condition at present and thanks
1. The last (from 1 to {k+s}) and first (from {r – k – s + 2}) digits of the number u do not show the contradiction.
2. Counter-examples are right.
3. My error: the digit u_{k+2} shows error.
4. The right solution: the digit u_{k + s + 1} shows error (k + s is maximum rank of the number u).
Deciding Lemma:
If U_(t + 1) = 0, then U*' _{t + 1} = U_{t + 1} (corollary from 21° - 25° in the Proof).
Idea of the new proof:
After transformation of the digit u_{k + s + 1} into 1 (with multiplication by 1 + n^(s+1)), we see that
U* _{ k + s + 1} = U*'' _{ k + s + 1} = 1 and hence U*'_{ k + s + 1} = –1.
Therefore up to multiplication U' _{ k + s + 1} = –1 and hence U _{ k + s + 1} = –1 =/ 0.
Let's come back to the discussion of the original proof in new version.
Dear Hurkyl, moshek, Robert Ihnot and Ramsay2879,
I would like to thank you all for your active participation and for your help
Victor
Dear Victor,
Please call me Moshe. Since 1980 my investigation is about the Organic unity of mathematics, and it's hidden connection to physics ( Please read the end of Hilbert lecture at Paris 1900).
I would like now to start and studies carefully all the details your interesting Organic work about FLT at your web-site :
Did you correct there already your mistake?
Another very interesting attitude to FLT I found yesterday here:
http://noticingnumbers.net/FLTsummary.htm
Yours :smile:
Moshe
Hurky:
Could it be, that mathematical true today come to a very exited point that it depend on a personal opinion of the mathematitioan ?
Moshe
According to the Russian paper Pravda, "Fermat's theorem is the unproved theorem indicating that the equation xn + yn = zn has no solution for x,y,z nonzero integers when n is greater than 2."
However, the matter has changed: "Doctor of Technical Sciences Alexander Ilyin will present his proof of Fermat's theorem at a meeting to be held at the Academy of Aviation and Aeronautics. His colleagues in Omsk believe Alexander's proof is flawless and simple." [/I][PLAIN]http://english.pravda.ru/science/19/94/377/16036_Fermat.html[/URL]
Remember you heard it here first!
Your question is unclear... anyways, I think the answer is "Mathematical facts do not depend on opinion"... in fact, the sciences are generally set up to reduce or eliminate subjective influences.
When is this proof going to be presented?
moshek said:
Dear Victor,
Yours :smile:
Moshe
No! There are still corrections to be made in the web page that Victor cites above. A few corrections follow:
Victor Sorokine 8/6/05 said:
Dear Hurkyl,
1. Your counter-example is right.
2. Congratulation!
3. Thank You very much!
Unfortunately, the cited web page still does not account for the counter examples.
First, it even does not agree with Victors allegation that in his proof u'_{k + 1} =/ 0! On the contrary the cited proof contains the following: “(5°) u'k+1 = (–1, 0 or 1) – because – nk < a'(k) < nk, – nk < b'(k) < nk, – nk < c'(k) < nk
and the numbers a, b, c have different signs”
Thus I propose the following correction here. Specify the following additional conditions (1) a,b,c must all be greater than 0 with c greater than a or b and less than a+b. It is easy to show that this does not impose a meaningful limitation on the proof and it overcomes any counterexample presented so far.
Second the cited web page further does not agree with his current position as of 8/25/05. See below.
Deciding Lemma:
The web page says nothing about these new definitions of u, U’, U* etc with respect to k+s+1. It still contains the allegation that the error shows up at U'_k+2 contrary to Victor's current position.
0. b < a < c.
...Should not "n - 2 with result 566...662" be --n - 1 with result 566...661--?
To be continued
It appears that Victor's current position is that a,b and c should be multiplied first by d to give u = ZZZZZZ00000 where Z=n-1, the number of Z's is "s" and the number of 0's is k. Secondly, multiply the new a,b,c by (n-1) to give u=YZZZZZ10000 where Y=n-2 the number of Z's is s-1 and the number of zeros remains k. He has presented this position piecemeal and his posts are only in outline form and contain typographical errors that are significant to an understanding of the proof. We have given plenty of time to respond to Victor in a meaningful way. He owes it to us (and especially to you given your willingness to verify his proof) to explain his present position in a clear manner in a single post which has been checked for errors and which can be followed without undue effort.
