Eliminating the parameter in parametric logarithmic equations
8 replies · 3K views · last reply
Witcher
I haven’t done logs in a few month and let alone with parametric graphs. I am having trouble with this problem. #35
X=e^t, y=e^3t
I got stuck when i eliminated the parameter.
  • Handwritten work on lined paper for problem 35: x = e^t, y = e^(3t). Below, ln x = ln e^t gives ln x = t, and y = e^(3(ln x)) is written beside it.
  • Photo of a printed precalculus homework worksheet listing Section 10.6 parametric equation problems and Section 10.7 polar and rectangular coordinate conversion problems, with some problem numbers in red.
Witcher said:
I got stuck
in full sight of the harbour as they say in shipping language: ##y = e^{3\log x}## should remind you of something like ##e^{ab} = e^{ba}##
[edit]I use ##\log## for e based logarithms. Only engineers confuse e and 10, which is why they need ##\log## and ##\ln## :smile: .
You have [itex]x= e^t[/itex] and [itex]y= e^{3t}= (e^t)^3[/itex] so [itex]y= x^3[/itex]. I don't see any reason to use logarithms.
You can keep “e^t” and isolate t without using logrithms?
Yes, because you don't need to isolate t. As has already been explained, ##e^{3t} = (e^t)^3##, so you can write y in terms of x, getting rid of the parameter t.
Witcher said:
Homework Statement:: I haven’t done logs in a few month and let alone with parametric graphs. I am having trouble with this problem. #35
Homework Equations:: X=e^t, y=e^3t
Hello, @Witcher . I see that you've been a member for a couple of months, but why not give you a welcome?
:welcome:
You have been led to and/or given shorter ways to the answer, but your start was OK.
Handwritten solution to problem 35: x = e^t, y = e^(3t), then ln x = ln e^t, ln x = t, and y = e^(3(ln x)), all written on lined paper.
Recall that ##\ \ C\cdot \ln(x) = \ln(x^C) ##.
Apply that to ##\ \ 3(\ln(x)) ##, and proceed .
I get it now but it wasn’t easy, my instinct was to Ln both sides when i seen the e
Thanks.
Witcher said:
I get it now but it wasn’t easy, my instinct was to Ln both sides when i seen the e.
Thanks.
As I mentioned, the path you started down was fine. It makes sense to work with the logarithm rules you may currently be studying and/or those rules you are most familiar with.
Carrying on from where you left off, (with ##\displaystyle y=e^{3(\ln(x))} ##):
You then have ##\displaystyle y=e^{\ln(x^3)} ##.
The final result follows immediately. (I hope.)
One can also use the fact that ##a^{bc}=(a^b)^c##.
