EM Theory: Refractive index of water
The refractive index of sea water is approximately 1.34, despite a low-frequency dielectric constant (k) of 80. This discrepancy arises because the refractive index is frequency-dependent, a phenomenon known as dispersion. The relationship n = √k, derived from Maxwell's equations, is only applicable to simple gases and does not hold for water. The dispersion equation n²(ω) = 1 + A (1/(ω₀² - ω²)) illustrates that at low frequencies, the refractive index exceeds 1 due to resonance effects.
  • Understanding of dielectric constants and their significance in optics
  • Familiarity with Maxwell's equations and their application to refractive index calculations
  • Knowledge of dispersion and its impact on the refractive index
  • Basic concepts of frequency dependence in optical materials
  • Study the principles of dielectric materials and their optical properties
  • Learn about the dispersion relation in optics and its mathematical formulation
  • Explore the frequency-dependent behavior of various materials, particularly water
  • Review Maxwell's equations in the context of electromagnetic wave propagation
Students and professionals in physics, optical engineering, and materials science who are interested in understanding the optical properties of water and other dielectric materials.
samreen
Problem: Sea water has k = 80 in the low frequency limit. Yet its refractive index is around 1.34. Explain the discrepancy
For a non magnetic dielectric medium, the absolute refractive index in the low frequency range, is given by : n = √k where k = Є/ Єo is the dielectric constant of the medium. Є and Єo are the permittivities of the medium and free space, respectively.
No idea. Does it have anything to do with the fact that water shows a wide variety of behaviour in various frequency ranges?
Note: this relation [tex]n \simeq \sqrt{K_{\epsilon}}[/tex] (Maxwell Relation) only holds for simple gases (air, Helium, Hydrogen).
For water, this relation doesn't work well because [tex]K_{\epsilon}[/tex] and then n are actually frequency-dependent, known as 'dispersion'.
You can consult to your Optics book for the dispersion eqn. I only summarize dispersion eqn, as:
[tex]n^2(\omega) = 1 + A (\frac{1}{\omega^2_0 - \omega^2})[/tex], A is constant value.
you see, if the frequency ([tex]\omega[/tex])is low (as your question) than resonance [tex]\omega_0[/tex], the refractive index will be greater than 1. so in case for sea water, n is about 1.34
