Emission in hydrogen atom: recoil and photon properties
The discussion focuses on the photon emission process in a hydrogen atom transitioning from the excited state ^2P_{1/2} to the ground state ^2S_{1/2}. The emission occurs without an external magnetic field, resulting in a photon with a wavelength of 1,215.674 Å. The momentum of the emitted photon imparts recoil to the hydrogen atom, calculated as p=h/λ, leading to a detection time of approximately 3.1 ms. The conversation also addresses the conservation of angular momentum and the conditions for allowed transitions, specifically the requirement of Δj=±1 and the implications of spin conservation.
  • Understanding of quantum mechanics, particularly atomic transitions.
  • Familiarity with dipole transitions and selection rules.
  • Knowledge of angular momentum in quantum systems.
  • Basic grasp of photon properties, including momentum and wavelength.
  • Study the principles of dipole transitions in quantum mechanics.
  • Learn about angular momentum coupling and its implications in atomic physics.
  • Research the conservation laws in quantum transitions, focusing on spin and angular momentum.
  • Explore experimental setups for observing atomic transitions and photon emissions.
Physicists, particularly those specializing in quantum mechanics and atomic physics, as well as students seeking to deepen their understanding of photon emission processes and atomic transitions.
deccard
I have been trying to picture the whole process of a photon emission by a atom. So to have good understanding what is going on, I have came up with following experimental setup. A single hydrogen atom in excited state ^2\!P_{1/2}, which has been orientated with a magnetic field so that precession of its total angular momentum is pointing to +z axis. The hydrogen atom is located at rest in the middle of a hollow spherical detector with radius r=1cm.
Now, without of the presence of any external magnetic field, the excited state is relaxed to the ground state in the dipole transition ^2\!P_{1/2}\rightarrow^2\!\!S_{1/2} with an emission of a photon with wavelength \lambda=1 215.674\textrm{\AA}.
Okay now to the questions:
1.
As the emitted photon has momentum p=h/\lambda, we get that the hydrogen atom is given recoil p=h/\lambda=mv. So the time between the detection of the photon and detection of the hydrogen atom at the detector is
t=\frac{r\lambda m}{h}=3.1\textrm{ms},
where m is the mass of hydrogen atom.
right?
2.
Because J=j=l+s=1/2, the state ^2\!P_{1/2} can have following configurations with notation\right \left| l,m_l,m_s\rangle
\right \left| 1,+1,-1/2\rangle
\right \left| 1,-1,+1/2\rangle
\right \left| 1,0,+1/2\rangle
\right \left| 1,0,-1/2\rangle
and so, as the spin doesn't change, the transition can be one of these
\right \left| 1,+1,-1/2\rangle \rightarrow \right \left| 0,0,-1/2\rangle
\right \left| 1,-1,+1/2\rangle \rightarrow \right \left| 0,0,+1/2\rangle
\right \left| 1,0,+1/2\rangle \rightarrow \right \left| 0,0,+1/2\rangle
\right \left| 1,0,-1/2\rangle \rightarrow \right \left| 0,0,-1/2\rangle
right?
3.
Is the reason for the unchanging spin the need of \Delta j=\pm1? Photon has spin \pm1 and in dipole transition we must have \Delta l=\pm1. Which would mean that we are left with \Delta s=0.
I will continue my questions when these are answered.
1. Seems fine with me. Kind of a contrived situation, though.
2. Seems fine.
3. Right. (assuming LS-coupling)
Now, I am little bit confused. I have started to doubt the permissibility of the two transitions below. (With \right \left| l,m_l,m_s\rangle )
<br /> \right \left| 1,0,+1/2\rangle \rightarrow \right \left| 0,0,+1/2\rangle<br />
<br /> \right \left| 1,0,-1/2\rangle \rightarrow \right \left| 0,0,-1/2\rangle<br />
In the transition ^2\!P_{1/2}\rightarrow^2\!\!S_{1/2} we have \Delta J=0, so a transition which has \Delta m_{j}=0 cannot occur. Can I calculate \Delta m_{j} as
\Delta m_{j} = m_{ji}-m_{jf}=m_{li}+m_{si}-(m_{lf}+m_{sf})
where indices i f represent initial and final states respectively?
If I can, this would give for the transitions \Delta m_{j}=0, which would then make the transitions forbidden.
On the other hand in the transition we have \Delta l=1 and \Delta m_{l}=0, which should be enough to make the transition allowed.
So... If some one could elaborate this little more.
  • · Replies 38 ·
  • · Replies 18 ·
