How Do I Calculate the Correct Percent Composition of Oxygen in a Compound?
  • Thread starter Thread starter limofunder
    Composition
To calculate the correct percent composition of oxygen in the compound SiO2, Na2, K2O, and PbO, one must consider the individual contributions of oxygen from each oxide based on their respective molar masses. The initial calculations incorrectly added the oxygen contributions directly, resulting in an unrealistic percentage over 100%. Instead, starting with a hypothetical 100 g of the compound allows for accurate determination of the grams of each oxide and the corresponding grams of oxygen they contain. Using this method, the total mass of oxygen can be divided by the total mass of the compound to find the correct percent composition. This approach ensures accurate results by accounting for the different amounts of oxygen in each oxide.
limofunder
I am running an experiment in which I have a compound of SiO2 Na2 K2O PbO I am trying to figure out the percent composition of oxygen given that the percent composition of the compound is:
46% SiO2
5% Na2
4% K2O
and 45% PbO
46% SiO2
5% Na2
4% K2O
and 45% PbO
So I figured given the previous percentages, the compound is made of
.46 SiO_2 * \frac{2 mol O }{1 mol SiO_2} + .04 K_2O * \frac{1 mol O}{1 mol K_2O} + .45 PbO * \frac{1 mol O}{1 mol PbO} = .46*2+.04+.45 = 1.41
but this gives me 141% oxygen composition, what am I doing wrong here? Its been a while since I took general chem (about 3 years ago) and my stoichiometry is not at its best right now.
would it be more correct to say that the percent composition of oxygen is:
0.46* \frac{2}{3}O + .04* \frac{1}{2}O+ 0.45* \frac{1}{2}O
= .5516 = 55.2%?
or would it be easier if I do the calculation by breaking it down into atomic masses, add the total of oxygen mass divided by the total mass of the compound?
thanks fellas, once again, couldn't have done it without yall.
You are adding apples and oranges. Each of these oxides contains different amount of oxygen (mass of oxygen per mass of the oxide), you can't add them this way. As you have already (and correctly) noticed, that gives idiotic results (percentage above 100%).
Your last approach is correct. Think this way: SiO2 is 46% of the substance. Assume you start with 100 g of the substance. How many grams of SiO2? How many grams of O in these grams of SiO2? (That's where the molar masses come into play).
16K
  • · Replies 18 ·
