Energy conservation in circular motion
5 replies · 2K views · last reply
Fatima Hasan
An object of mass m = 1 kg moves along a circular frictionless path of radius R = 0.5 m from point A to point B at which it makes an angle θ with the vertical direction as shown in the figure. If the object is release from rest (VA = 0) and θ = 30° , what is the normal force at point B (in N) ?
Hand-drawn diagram of a circular frictionless track with centre marked, radius R, points A on the left at the level of the centre and B lower right at angle θ from the vertical dashed line, with blocks at A and B.
A ) 2.98 B) 25.98 C) 28.19 D) 29.54
Two equations in plain text: F = ma, and a_c = v^2 / r, where a_c is centripetal acceleration, v is speed and r is radius.
3. The Attempt at a Solution [/B]
Here's my work :
Handwritten solution steps for a circular-motion energy problem: E1 = E2, mgh = mgh + 0.5kv^2, leading through v^2 = 1.33 m/s, a = 2.67 m/s^2, F = ma = 2.67 N, to mgcosΘ − FN = 2.67 and FN = 5.93 N.
  • Hand-drawn diagram of a circular frictionless track with centre marked, radius R, points A on the left at the level of the centre and B lower right at angle θ from the vertical dashed line, with blocks at A and B.
  • Two equations in plain text: F = ma, and a_c = v^2 / r, where a_c is centripetal acceleration, v is speed and r is radius.
  • Handwritten solution steps for a circular-motion energy problem: E1 = E2, mgh = mgh + 0.5kv^2, leading through v^2 = 1.33 m/s, a = 2.67 m/s^2, F = ma = 2.67 N, to mgcosΘ − FN = 2.67 and FN = 5.93 N.
    %5CF%3Dma%5C%5CF%3D2.67%20N%5C%5Cmg%20cos%20%5CTheta%20-FN%3D2.67%5C%5C8.6-FN%3D2.67%5C%5CFN%3D5.gif
Here's my work :
Your work is wrong. What is k?
You can not write gh=gh+0.5v^2. It means that the v2=0.
K is a typo. It should be m
gh1 = gh2 + 0.5 v^2
gh1 = gh2 + 0.5 v^2
It is better now, but your v2is wrong.
I found the mistake. The height in B, I should substract it from 0.5
The answer is 25.98
The answer is 25.98
Well done!
