Energy in co-moving co-ordinates?
  • Context: Graduate
  • Thread starter Thread starter johne1618
    Energy
The discussion revolves around the energy of a quantum system in co-moving coordinates, particularly in the context of cosmological time and the implications of scale factors on Planck's constant and energy measurements. Participants explore theoretical frameworks, definitions, and implications for energy density in an expanding universe.
  • One participant proposes that the energy of a quantum system in co-moving coordinates can be expressed as Eτ = a(t) Et, where Et is the energy in cosmological time.
  • Several participants challenge the initial claim, arguing that if time and length scales are time-dependent, then Planck's constant (h) must also change, affecting the interpretation of energy.
  • Another participant suggests that using units where h is unity could simplify the analysis, but questions remain about the implications for energy in the co-moving frame.
  • Some participants discuss the relationship between the momentum of photons and the scale factor, asserting that there is no assumption that Planck's constant changes with the length scale in standard proper coordinates.
  • One participant emphasizes the importance of definitions in the coordinate system, noting that different interpretations of length and time intervals lead to different conclusions about the constancy of h.
  • A later reply introduces the idea of defining time intervals in a co-moving frame, suggesting that if atomic lengths are constant, then Planck's constant remains unchanged, leading to a different energy density behavior than typically expected.
  • Another participant states that under General Relativity, a global definition of energy is problematic, adding complexity to the discussion.
Participants express multiple competing views regarding the behavior of Planck's constant and energy in co-moving coordinates. There is no consensus on whether h remains constant or varies with the scale factor, and the implications for energy density in an expanding universe are also contested.
Participants highlight the dependence on definitions of time and length scales, and the unresolved nature of how these definitions affect the interpretation of physical constants like Planck's constant.
johne1618
Consider the energy of a quantum system
E_t = h f
E_t = \frac{h}{\Delta t}
where \Delta t is the period of the quantum system in cosmological time t.
What is the energy of the system in co-moving co-ordinates?
In co-moving co-ordinates time is measured in conformal time \tau given by
\Delta \tau = \frac{\Delta t}{a(t)}
Thus the energy of the co-moving quantum system is given by
E_\tau = \frac{h}{\Delta \tau}
E_\tau = a(t) \frac{h}{\Delta t}
E_\tau = a(t) E_t
Is this correct?
Space news on Phys.org
No. If you impose a time-dependent time (and/or length) scale, then h is also changing, as is the relative meaning of E.
BillSaltLake said:
No. If you impose a time-dependent time (and/or length) scale, then h is also changing.
But surely one can use units such that h is unity.
One can understand the cooling CMB in the comoving frame in this manner. The CMB photon energy is fixed (no expansion of space) but the energy of comoving systems is increasing. The effect is that a photon emitted from some type of atom in the past is effectively redshifted relative to a comoving atom of the same type in the present epoch as the atom's energy has increased whereas the photon has the same energy as the atom in the past.
h has units of (mass)(length2)(time-1). If the time measurement unit is changing, then h must become variable, whether you let l units change in ratio with t units or keep l units constant. Similarly, E has units of ml2t-2, so if you keep c constant by letting l and t units vary in ratio, then E is unchanged. However, if c is a constant, then E = E' = hf = h'f ' other than a trivial scaling constant.
But in the standard proper co-ordinates in which the Universe is expanding it is understood that the momentum of photons is inversely proportional to the scale factor. As far as I can see there is no assumption that Planck's constant changes as the length scale changes. So why should Planck's constant change in co-moving co-ordinates?
As with most things, one must be careful of definitions. I assume your coordinate system defines v=0 locally as 'at rest with respect to CMB'. However, there are two different ways that lengths (and time intervals) can then be defined. The "normal" way (such as CGS or MKS, for example) interprets atomic lengths, such as wooden yardsticks, as constant. Then the distance between distant objects increases \propto a. Of course h is a constant in this case.
If your lengths and time intervals instead scale with a, so that distant objects appear to maintain ~constant distance, then the value of h will decrease over time (h \propto 1/a).
Ok, in a co-moving frame in which units are such that atomic lengths are constant, I presume I can define a small interval of time d\tau as the time it takes light to travel along a constant length element dr so that
d\tau = dr / c
Now the Freidmann metric says that light obeys the relation
c \ dt = a \ dr
Therefore
d\tau = dt / a(t)
Therefore in a co-moving frame, in which atomic lengths are constant, one uses conformal time where an interval of conformal time d\tau \propto 1/a.
Have I got this correct?
If the above is right then one can say the energy of a quantum system with period d\tau is given by
E = h / d\tau
E \propto a(t)
as Planck's constant is actually constant.
If the above was true then the energy density of matter would go like
\rho \propto \frac{a}{a^3}
\rho \propto \frac{1}{a^2}
instead of \rho \propto 1/a^3
This would give a linearly expanding Universe.
Under GR, a global definition of energy defies explanation.
