Enhancing Your Science Knowledge: Introducing the Resources Section on PF
  • Context: Suggestion
  • Thread starter Thread starter Anti-Meson
54 replies · 8K views
Anti-Meson
All too often members of this forum are referencing wikipedia and I believe that site does not offer a valid representational view of science. The reason why members quote from wikipedia is that we often type words into google and the first result is wikipedia - no surprise.
I am all for thinking analytically and critically and so I propose a "Resources" section in header section of PF, in between library and staff. This section would pose as a link library to various websites and alternatives to google and wikipedia. This could be expanded by giving it a separate section in the forums where members can post new links and moderators can then decide which ones to add to the resources section. If this went ahead then it would hopefully promote people not to use wikipedia.
Discuss.
Not a bad idea, but I believe it's already partially present in the "Math & Science Learning Materials" forum.
As for Wikipedia results, well, it depends on the nature of the thread. They can be sufficiently effective for homework helping threads.
I am not convinced that it should be used by students wishing to learn about a subject nor does wikipedia founder Jimmy Wales:
Do you think students and researchers should cite Wikipedia?
No, I don't think people should cite it, and I don't think people should cite Britannica, either - the error rate there isn't very good. People shouldn't be citing encyclopedias in the first place.
from http://www.businessweek.com/technology/content/dec2005/tc20051214_441708.htm
Perhaps more useful sites would be http://intute.ac.uk, http://infomine.ucr.edu/ to name a couple.
It shouldn't be used (and it cannot be used) to "learn a subject", of course. But it can be used as a quick and effective reference. The sites you gave here (I tried them out a bit) give links to different web-sites with lecture notes, etc. which is great stuff - but I still believe Wikipedia can be useful as a very quick reference when you're searching for a definition for something. The purpose of these sites is different - so we can't compare them to Wikipedia and say that they are or are not more useful.
Regardless of wikipedia is used or not we ought to promote alternatives. A point on which we both agree on.
Of course, we both agree on that one. But it's only the question if such a source is necessary with the "Math & Science Learning Materials" present.
I am suggesting a link library to scientific search engines, databases and electronic journals subscription based and free rather than learning material. Think of it as a reference library of links.
1. There is already a resource forum called the Learning Materials forum.
2. Wikipedia should always be used with caution.
3. In most cases, valid websites and peer-reviewed publication trumps over Wikipedia references.
4. Frequent inappropriate references to Wikipedia are often made by those who are using it without understanding the physics.
HOWEVER...
5. The use of Wikpedia as a reference by those who DO know the physics is perfectly valid and often useful.
There are enough physics Mentors and Science Advisors on this forum that the proper and appropriate use of any references, including Wikipedia, are closely monitored. As far as I can tell, there hasn't been any incidents (or there aren't that many of them) where the inappropriate usage were allowed, or went unchallenged.
So from my point of view, I don't think this is even an issue.
Zz.
Ok I see what you are getting at Zz, forget the name resources or reference. All I am stating is that there ought to be somewhere on PF that is easily accessible and provides links to scientific search engines and databases independent of textbook material which belongs in learning material.
Learning materials on PF provides what a textbook does it tutors you on concepts. By idea is that we compile a list of search engines so when arguing in PF you can quote from a paper or so on with confidence.
This is a bit puzzling. Most of peer-reviewed papers can't be found using a "search engine", since they are usually accessed via subscriptions.
Again, you are proposing something to solve for what I think is a non-existent problem. I believe that we have always tried to maintain a large signal-to-noise ratio in the physics subforums, and have always insisted on proper and valid sources as citations. So I'm not sure why this issue is being discussed here. Do you see something that I don't see going on here?
Zz.
I agree with you on that most peer-reviewed papers can't be accessed for free. However links such as intute and infomine are free.
Zz.
Unfortunately I see too often PF staff quoting unreliable and dubious sources, such as wikipedia more frequently than I should.
Maybe a sticky can be identically posted in each subforum outlining good links and such.
Again, one of the points I brought up above is that, if used by knowledgeable people, in the right context, I don't see anything wrong with it. We have plenty of people here that will monitor such usage. I don't see such rampant misuse of it in the physics subforum.
So why is this a problem with you?
Zz.
There is nothing wrong with offering Wiki articles as a first line, to encourage further reading. Wiki articles list resources at the bottom for this. This is one way of allowing members to do their own homework, rather than us having to "educate" them.
But Wiki should not, and rarely is, used as any kind of authority.
Zz.
The problem is knowledgeable people using wikipedia. They ought not to, instead draw upon their knowledge and provide authoritative facts from other websites. Wikipedia has no accountability and as such ought not to be used.
If this isn't hypocrisy, then I don't what is. DaveC426913, I have seen you on more than one occasion draw upon wikipedia for authority.
I do not believe in spoon-feeding people knowledge. I would rather point them into a direction where they can teach themselves as that is the only way to true understanding.
Your reaction confirms my suspicion that this thread was catalyzed https://www.physicsforums.com/showpost.php?p=2577641&postcount=16".
This thread is an oblique attempt to continue to defend yourself.
You've pretty much gotten your answer in both threads.
This thread is a suggestion thread. I see you show balance by giving just your view...
Anyway, back on track. Perhaps a sticky ought to be in every subforum highlighting the problem with wikipedia as a source and list some alternatives to use as citations.
I have the opposite opinion. We have a "PF library" here, with articles written by members of this forum, but the articles are usually not as good as the ones at Wikipedia. People often link to other web sites, and on average, their quality is far below Wikipedia standard as well. I think Wikipedia is (usually) a great reference, at least for definitions of mathematical terms and proofs of simple theorems.
Yes, there are bad articles there as well, but seriously, I'm sure I've seen more garbage claims and terrible explanations in peer reviewed journals than at Wikipedia.
It makes no sense to reinvent the wheel every time. If there's a good article at Wikipedia, why not use it? And those that do have accountability (peer reviewed journals) don't ever correct their mistakes. Sure, other articles can be published that point out the flaws, but they sometimes go unnoticed while people keep using the bad article as a reference 40 years later.
Can you explain to me what is great about an unauthoritative, unaccountable site such as wikipedia that leads to unreliability and inaccuracy?
It is no different than your citation for the 2nd law of thermodynamics. Why would you do such a thing when your "knowledge" should have been sufficient? Furthermore, your use of this "authoritative facts" was not relevant to the thread on hand.
Again, it is not just the source, it how it is used. I've seen people bastardized even valid sources and peer-reviewed journals. We monitored for those as well, not just the use of Wikipedia. You are fixated on only the source, without giving due consideration on how the source is used. I do not recommend the use of Wikipedia, and in fact, I don't remember ever using it as a source in all of my post on PF. However, there are many items in which knowledgeable people have used in which the information provided have been accurate.
As of now, I still have not seen ample evidence and convincing argument that support what you are proposing. So I would not be in favor of having such "resource section".
Zz.
If only this was valid what a simpler world we would live in. The "trust me I know it" or the "just take my word for it" argument sadly doesn't stack up that is why we reference, we supplement our argument through citations and by doing this provides evidence.
Couldn't agree with you more. We should be careful on how we use sources. Where my argument is against wikipedia, is primarily, its accountability, you simply do not know who wrote it. This is a problem because if you do quote wikipedia and by doing so get your facts wrong you cannot hold anyone to account for producing inaccurate material and maybe ridiculed for getting it wrong. Other sites for example usually print their authors and so when you do quote from these and get it wrong then at least you will be able to second thought other information given by this author elsewhere on the internet. With wikipedia, if you get it wrong you can argue that the whole site is inaccurate as you cannot pinpoint the inaccurate information that you did receive on anyone or group of people.
Anti-Meson said:
If only this was valid what a simpler world we would live in. The "trust me I know it" or the "just take my word for it" argument sadly doesn't stack up that is why we reference, we supplement our argument through citations and by doing this provide evidence.
Then you are more than welcome to stick to the references that you know to be valid.
.. and that's why we have a lot of quality control on here. You have been here for... er.. how long? We have had to remove many references to Wikipedia, and other sources, in which (i) the sources were wrong and/or (ii) the sources were used for the wrong reasons/conclusions.
If you see Wikipedia article that is faulty, or being used in the wrong manner, report it. Other members certainly did, and will continue to do so. It is why we have quality control in this forum. It is also why the reason given to create such a resource section is weak.
Zz.
Zz.
Forget about your perceivance of my original suggestion. What I am suggesting now is that PF creates a sticky or page of links to sources on the web which can be cited, think of it as a link library.
Say we do as you suggest. What happens when someone references a link that is not on that list? Is their link trumped by an officially-condoned PF link?
No the link library, as with any library, is not set in stone, it would be dynamical and need constant updating. If a new link arises a moderator would have to check of whether it is worthy of being in said library.
You misunderstand.
Say the library currently has 481 links in it. A member comes along making a claim - and supports it by linking to a site that is not in the list of 481 accepted links.
How is that member's claim treated? Is his claim considered just as valid despite not referencing an "approved" link?
In other words, are you proposing that PF move to a system where claims must reference approved sites to be accepted?
DaveC426913 said:
You misunderstand.
His link, as with every source should be evaluated, if it is credible enough then it ought to be added to said link library. There would of course have to be some guidelines in the link library so as to encompass similar sites such as journals.
For example, instead of providing the links to all the know scientific journals, it would be treated like this or to this effect:
Scientific Journals such as Nature, Physical Review would all come under the header "Physics Journals".
Anti-Meson said:
His link, as with every source should be evaluated, if it iscredible enough then it ought to be added to said link library.
OK but what happens to his post in the meantime? Is he simply told "Your post references an unapproved link.This thread will be locked while the link is evaluated by our approval committtee. If found acceptable, it will be added to our library. Once that is done, we will unlock this thread."
DaveC426913 said:
OK so what happens to his post in the meantime? Is he simply told "Your post references an unapproved link.This thread will be locked while the link is evaluated by our approval committtee. If found acceptable, it will be added to our library. Once that is done, we will unlock this thread."
I don't think locking the threading would be constructive. Perhaps flagging the post up with a comment such as "post in evaluation process" or something to that effect. So something like a flagging option would highlight to future posts that this post currently should be taken with a pinch of salt, until evaluated.
So PF becomes, rather than an open forum inviting new ideas that are not already here, a closed forum where the only things being discussed are things that have been approved?
I keep thinking of Wells' Animal Farm.
Woah! Hold it there. You are going down a slippery slope. I haven't mentioned nor proposed a closed forum, I enjoy PF being open to new ideas. What I am proposing is that a link library be established with a list of credible sources to use in arguments. Original thought does not necessarily require citations.
On a side note, don't you mean Orwell's Animal Farm?
