Why Does Cs React More Violently with Water than Li?
  • Thread starter Thread starter broegger
Cesium (Cs) reacts more violently with water than lithium (Li) despite Li having a higher enthalpy of hydration due to its smaller atomic radius, which influences the ease of electron loss. The reaction rates differ significantly, with Cs exhibiting a faster reaction rate compared to Li, leading to more vigorous reactions. Factors such as atomic size and the nature of the redox reactions play crucial roles in determining the reaction dynamics. The enthalpy of hydration, which reflects the energy change when ions interact with water, is not the sole determinant of reaction intensity. Understanding these concepts clarifies why Cs's reaction is more explosive than that of Li when both are exposed to water.
broegger
Hi.
How come that Cs reacts more violently with water than Li, when the enthalpy of hydration for Li is -520 kJ/mol while it is only -276 kJ/mol for Cs. More energy is released in the Li reaction, but still it reacts more quietly?
(EDIT: Oops, maybe this should be in the homework section?)
What else affects the reaction? It ain't ALL enthalpy of hydration.
Yes, for instance, consider the radii of the elements.
There will occur a redoxreaction when Li and Cs are put in water. What happens in this reaction with Li and Cs in this redoxreaction ? In combination to the previous post it should answer your question.
The Li atoms are smaller, but how does that affect the reaction?
compare:
Li --> Li(+) + e(-) and Cs --> Cs(+) + e(-)
in what electron lies more energy ? and what electron is easiest being lost ?
How on Earth do you spec an enthalpy of hydration for an atomic species (like Li or Cs)? What does that even mean? Would you (the OP) please define the enthalpy of hydration in this context?
Secondly, translate the words "violently" and "quietly" into terms involving well-defined physical quantites. The answer will pop right out.
I have no idea, just quoting from the book, basically. Doesn't Li- and Cs-solids exist? I'm a lousy chemist, I know.
I would think that "quietly" means slow and "violently" means fast, so the statement is that the reaction rate of Cs + water is larger than the reaction rate of Li + water. I understand that the reaction rate is influenced by other factors than the difference in enthalpy...
Okay --- step at a time: what's the first thing that happens when elemental Li or Cs are placed in contact with water? (Yes, they're both solids.)
the topic starter said: 'reacts more violently with water'
--> thus we speak about the reaction between elemental Li /Cs and water, i assume.
38K
