Enthelpy of water / ethanol at different ratios -- trend?
The discussion focuses on the enthalpy of water-ethanol mixtures at varying ratios, specifically addressing the unexpected trend line observed in the mixing enthalpy graph. It highlights that the mixing enthalpy does not follow a quadratic trend due to the influence of short-range ordering and clustering effects in the solution, rather than a simple random distribution of molecules. The regular solution model, which assumes a quadratic dependence based on concentration, fails to account for these interactions, leading to different enthalpy values depending on the ratio of small to large molecules in the mixture.
  • Understanding of enthalpy and thermodynamic principles
  • Familiarity with regular solution models in chemistry
  • Knowledge of molecular interactions and clustering effects
  • Basic graph interpretation skills for analyzing enthalpy trends
  • Research the concept of short-range ordering in solutions
  • Study the regular solution model and its limitations
  • Explore molecular interaction theories, particularly in mixtures
  • Learn about enthalpy calculations for different solvent mixtures
Chemists, chemical engineers, and students studying thermodynamics or solution chemistry who are interested in the behavior of solvent mixtures and enthalpy trends.
Jackymoon13
Hello,
I was doing some research on enthalpy of water-ethanol mixtures at different ratios, and when looking at all the information graphed, I don't understand why it produces the trend line it does. Why doesn't it produce a 'quadratic' trend line? Shouldn't having a 10:90 water-ethanol exert the same amount of energy that a 90:10 ratio would?
The graph in question: https://i.stack.imgur.com/lgSbi.png
Thanks.
Chemistry news on Phys.org
I suppose that you are thinking of a description of the mixing enthalpy in terms of a regular solution model which gives a 'quadratic' dependence as a function of concentration. Regular solution models assume that the short-range environment around a given molecule can be expressed in terms of a random distribution of the constituents, viz. in terms of overall concentration values. In reality, however, one has to think about clusters (central molecule + environment) with a certain short-range ordering. Assume, as a simple example, that one has mixture of small molecules A and much larger molecules B (with attractive interactions between A and B). The mixing enthalpy will be different whether one dilutes a few small molecules in a sea of large molecules or vice versa.
27K
  • · Replies 16 ·
  • · Replies 74 ·
  • · Replies 17 ·
10K
10K
  • · Replies 32 ·
11K
