Kakashi
- 30
- 1
- Homework Statement
- A prize is randomly placed in one of ten boxes, numbered 1-10 through with each box equally likely. You search for the prize by asking yes–no questions. Let X denote the number of questions required until you are certain of the prize’s location.
Find the expected value E[X] under each of the following strategies:
(a) Enumeration strategy:
You ask questions of the form “Is the prize in box k?" starting from 𝑘=1 and proceeding sequentially.
(b) Bisection strategy:
At each step, you eliminate as close to half of the remaining boxes as possible by asking questions of the form “Is the prize in a box numbered less than or equal to 𝑘?”
- Relevant Equations
- E[X]=∑xP(x)
Let tX=Number of questions asked.
Enumeration Strategy:
I ask questions of the form: "Is it in box k?" starting from k=1
Initially each box has probability 1/10. If the answer to "Is it in box 1?" is no, then the prize is uniformly distributed among the remaining 9 boxes and so on. If the prize is in box k then exactly k questions are required. Therefore.
$$ P(X=k)=1/10 , k=1,2,..,10 $$
$$ E[X]=\sum_{k=1}^{10} kP(k)=5.5 $$
Bisection Strategy
To minimize the expected number of questions the first question is "Is it in a box<=5?"
This splits the boxes into {1,2,3,4,5} and {6,7,8,9,10} each with a probability of 1/2.
If the answer is yes, I split {1,2,3,4,5} into {1,2,3} and {4,5} and ask if the prize is in {1,2,3}?
If the answer is no, then the prize is in {4,5}. I split this into {4} and {5} and ask if the prize is in box {4}. In this case the prize is identified in 3 questions.
If the answer is yes, then the prize is in {1,2,3}. I split into {1,2} and {3} and ask if the prize is in {1,2}.
If the answer is no, the prize is in box 3 and is identified in 3 questions.
If the answer is yes I split {1,2} into {1} and {2} and ask if the prize is in box {1}. In this case the prize is identified in 4 questions.
A similar approach applies if the prize is in {6,7,8,9,10}.
If the prize is in {3,4,5,8,9,10} the prize is identified in 3 questions. If the prize is in {1,2,6,7} the prize is identified in 4 questions. Therefore E[X]=6/10*3+4*4/10=3.4
Is this reasoning for the bisection strategy correct? Is there a shorter way to calculate the expected value of X for the bisection stratetgy rather than going through all the possible paths?
Bisection Strategy
