Enumeration vs Bisection Strategy
  • Topic: Engineering
  • Thread starter Kakashi
2 replies · 3K views · last reply
Kakashi
A prize is randomly placed in one of ten boxes, numbered 1-10 through with each box equally likely. You search for the prize by asking yes–no questions. Let X denote the number of questions required until you are certain of the prize’s location.
Find the expected value E[X] under each of the following strategies:
(a) Enumeration strategy:
You ask questions of the form “Is the prize in box k?" starting from 𝑘=1 and proceeding sequentially.
(b) Bisection strategy:
At each step, you eliminate as close to half of the remaining boxes as possible by asking questions of the form “Is the prize in a box numbered less than or equal to 𝑘?”
E[X]=∑xP(x)
Let tX=Number of questions asked.
Enumeration Strategy:
I ask questions of the form: "Is it in box k?" starting from k=1
Initially each box has probability 1/10. If the answer to "Is it in box 1?" is no, then the prize is uniformly distributed among the remaining 9 boxes and so on. If the prize is in box k then exactly k questions are required. Therefore.
$$ P(X=k)=1/10 , k=1,2,..,10 $$
$$ E[X]=\sum_{k=1}^{10} kP(k)=5.5 $$
Bisection Strategy
To minimize the expected number of questions the first question is "Is it in a box<=5?"
This splits the boxes into {1,2,3,4,5} and {6,7,8,9,10} each with a probability of 1/2.
If the answer is yes, I split {1,2,3,4,5} into {1,2,3} and {4,5} and ask if the prize is in {1,2,3}?
If the answer is no, then the prize is in {4,5}. I split this into {4} and {5} and ask if the prize is in box {4}. In this case the prize is identified in 3 questions.
If the answer is yes, then the prize is in {1,2,3}. I split into {1,2} and {3} and ask if the prize is in {1,2}.
If the answer is no, the prize is in box 3 and is identified in 3 questions.
If the answer is yes I split {1,2} into {1} and {2} and ask if the prize is in box {1}. In this case the prize is identified in 4 questions.
A similar approach applies if the prize is in {6,7,8,9,10}.
If the prize is in {3,4,5,8,9,10} the prize is identified in 3 questions. If the prize is in {1,2,6,7} the prize is identified in 4 questions. Therefore E[X]=6/10*3+4*4/10=3.4
Is this reasoning for the bisection strategy correct? Is there a shorter way to calculate the expected value of X for the bisection stratetgy rather than going through all the possible paths?
Problem 19 text: a prize is randomly placed in one of ten numbered boxes, and the task is to find the expected number of yes-no questions under an enumeration strategy (is it in box k?) and a bisection strategy (is it in a box numbered at most k?).
Your reasoning is correct for the second part and I agree with your answer.
It might shed light on the problem, possibly leading to a smarter method, if you figure it out for all numbers of boxes up to 10. I observe an interesting pattern in how the average number of questions increases as the number of boxes increases.
##p_N/N##, where ##p_N## starts at 0 and increases in the pattern
+2
+3, +3
+4, +4, +4, +4
+5, +5, +5, +5, +5, +5, +5, +5,
This leads to the formula average ##=t+2-2\cdot 2^t/N##, where ##t=\lfloor \log_2N\rfloor##, but I have not attempted to prove it.
If we fix t and write ##N=2^{t+x}##, ##0\leq x\leq 1##, then average ##=t+2-2\cdot 2^{-x}##. This exceeds the obvious minimum value of ##t+x## by ##2(1-2^{-x})-x##. Plotting this against x produces a curve like an inverted parabola, but not quite symmetric. It reaches a maximum of ##1-\frac{1+\ln(\ln(2))}{\ln(2)}## at ##x=1+\frac{\ln(\ln(2))}{\ln(2)}##.
For the enumeration strategy:
Indeed, but notice the price is known to be in one of the boxes, so if you have 10 boxes do you then need all 10 questions?
For the bisection strategy:
In the given context this looks correct to me.
Bisection on a discrete set of ##N = 2^k## values can be done in exactly ##k## steps, so an overall estimate of how many steps it takes to bisect a set of ##N## values can be found as ##k\approx \log_2 N##.
