Epsilon-Delta Proof with 2-Variable Polynomial
  • Thread starter Thread starter idochemistry
    Polynomial Proof
The discussion revolves around finding a specific δ>0 such that if x² + y² = δ², then |x² + y² + 3xy + 180xy⁵| < 1/10,000. The context is within the framework of epsilon-delta definitions of limits in multivariable calculus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between the expression |x² + y² + 3xy + 180xy⁵| and δ, questioning how to bound the terms effectively. Some express confusion about manipulating inequalities and the implications of the triangle inequality. Others suggest examining the bounds for |x| and |y| based on the condition x² + y² < δ².
The discussion is ongoing, with participants providing hints and exploring various approaches to bounding the expression in question. There is recognition of the need to express the bounds in terms of δ, but no consensus has been reached on a definitive method or solution.
Participants note the importance of ensuring that the bounds depend solely on δ and not on the individual values of x or y. There is also a clarification that the expression |x² + y² + 3xy + 180xy⁵| may exceed δ², which raises further questions about the assumptions being made.
idochemistry
Find a specific number δ>0 such that if x2 + y2 = δ2, then |x2+y2+3xy+180xy5 < 1/10 000.
Answer: Choose δ < 0.002
ε-δ def'n of limit: lim (x,y) → (a, b) f(x) = L if for every ε > 0 there exists a δ > 0 such that 0 < √(x-a)2+(y-b)2, |f(x) - L| < ε.
So, f(x) = |x2+y2+3xy+180xy5 and because x2 + y2 = δ2, the limit is being taken as (x, y) → (0, 0) and L = 0.
I don't understand how I would start this problem because it's not rational, like I'm used to. I can do this:
(x) = |x2+y2+3xy+180xy5 = x2 + y2 + 3|x||y| + 180|x||y5|, but now I am stuck. Any help is greatly appreciated.
idochemistry said:
|x2+y2+3xy+180xy5| = x2 + y2 + 3|x||y| + 180|x||y5|, but now I am stuck. Any help is greatly appreciated.
Well, this equation is certainly not true, but if you replace the ##=## with ##\leq##, then it is true, because of the triangle inequality. So this gives you
$$|x^2 + y^2 + 3xy + 180xy^5| \leq |x^2 + y^2| + |3xy| + |180xy^5|$$
Assuming ##x## and ##y## are real, it's true that ##|x^2 + y^2| = x^2 + y^2##. And the absolute value of a product equals the product of absolute values. So we can rewrite the right hand side as
$$x^2 + y^2 + 3|x|\cdot |y| + 180 |x| \cdot |y|^5$$
You know that ##x^2 + y^2 = \delta^2##. Can you find a way to bound the other terms in a way that depends on ##\delta##?
Sorry, I meant to say that x2+y2 < δ^2
I am still very confused.
Can I do something like this?
0 ≤|x2 + y2 + 180xy5| ≤ x2 + y2 + |3xy| + |180xy5| ≤ |3x2y2|+|180x2y5| = |3x2y2(|1+60y3|)
It isn't necessarily true that ##|3xy| \leq |3x^2 y^2|## or that ##|180xy^5| \leq |180x^2 y^5|##. This is true if ##x \geq 1## and ##y \geq 1## but not in general.
Here is a hint. How does ##|x|## compare to ##\sqrt{x^2 + y^2}##?
No. You can't turn a sum into a product like that.
IOW, you can't do this: x2 + y2 + |3xy| + |180xy5| ≤ |3x2y2|+|180x2y5|
And you can't do what you did in the last expression, either.
Okay. So,
|x| ≤ [itex]\sqrt{}x<sup>2</sup>+y<sup>2</sup>[/itex]< δ
and
|y| ≤ [itex]\sqrt{}x<sup>2</sup>+y<sup>2</sup>[/itex]< δ
Then,
|x2+y2+3xy+180xy5| < δ+δ+3δ2+180δ6
Right?
Also, thank you so much!
idochemistry said:
Okay. So,
and
So far so good.
Then,
That's not quite right. Try writing out the intermediate steps:
$$\begin{align}
|x^2 + y^2 + 3xy + 180xy^5| & \leq x^2 + y^2 + 3|x| |y| + 180 |x| |y|^5 \\
& \leq \delta^2 + 3|x| |y| + 180 |x| |y|^5 \\
&\leq ?\end{align}$$
Isn't |x2+2+3xy+180xy5| ≤ δ2
ie. it doesn't matter what you add to the right side because it will always make δ2 larger, in this case?
You're trying to solve for ##\delta## which will satisfy the requirement in your problem statement. You need to find a bound for ##|x^2 + y^2 + 3xy + 180xy^5|## that depends only on ##\delta##, not ##x## or ##y##. You have the constraint ##x^2 + y^2 < \delta^2##. From this, in post #6 you found some bounds for ##|x|## and ##|y|##. Now apply those to the right hand side in post #7.
To address this question directly, no, it's not necessarily true. All you know is that ##x^2 + y^2 < \delta^2##. But ##|x^2 + y^2 + 3xy + 180xy^5|## may be bigger than ##x^2 + y^2##, so it isn't necessarily bounded by ##\delta^2##. Try plugging in ##x=y=1## and ##\delta = 2## to see this.
Waiiiiit. 4δ2 + 180δ6
would be the right side?
Yes, that looks right:
##3|x||y| < 3\delta^2##
##180|x||y|^5 < 180\delta^6##
so
##x^2 + y^2 + 3|x||y| + 180|x||y|^5 < 4\delta^2 + 180\delta^6##
