Equation Balancing: Is HCl + Na2S202 Balanced?
  • Thread starter Thread starter LVB
The discussion revolves around the balancing of the chemical equation HCl + Na2S2O2 --> NaCl + S + H2O + SO2. It is noted that there is a mistake in the formula for sodium thiosulphate, which should be Na2S2O3, affecting the ability to balance the equation correctly. Additionally, participants discuss methods for measuring the rate of reaction, specifically mentioning the mass measurement technique where the mass of reactants is weighed until a change occurs. A request for diagrams related to the experiment is made, with an emphasis on sharing helpful websites for reference.
LVB
is this equation balanced?
HCl + Na2s202 --> NaCl + S + H20 + SO2
Thank you for you help !
Lucy x
Chemistry news on Phys.org
Hello lucy it looks to me like you're doing the disappearing cross reaction rate experiment.I think you have the wrong formula for sodium thiosulphate,if so it's no wonder you're having trouble balancing it.Try again with Na2S2O3
oh yeah thank you!
something else ...
when measuring the rate of reaction, you can use the mass one. You know were you weigh the mass of the reactants until there is a change.
Does anyone know where i can find a diagram of this? Please leave websites if that is easiest.
Thank you muchly :blushing:
x
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
