Equation for set of linear graph lines
The original poster is seeking a single equation that can represent a set of six linear lines on a graph, where the dependent variable is x and the independent variable is y. Each line corresponds to a discrete constant z, specifically related to tire sizes.
  • Exploratory, Assumption checking
  • Participants are asking for more details about the equations of the lines and whether they are parallel. There is a focus on understanding the relationship between tire size and the slopes of the lines represented in the graph.
Some participants have expressed the need for additional information, such as a visual representation of the graph, to provide more targeted assistance. There is an ongoing exploration of potential relationships between tire width and pressure-load slopes based on the data provided.
The original poster mentions that the lines are not parallel and that the tire size is a variable of interest. There is an implication that the slopes of the lines may vary, which could affect the formulation of a generalized equation.
fdore45
Have graph of dependent variable x and independent variable y. The graph contains 6 linear lines representing 6 discrete constants z.
I'm looking for one equation that would represent all 6 of the linear lines...
Without seeing the y=y(x) equations for the 6 lines, it would be difficult for me to give you a helpful answer to the general problem. Can you provide a little more details? Are the lines parallel?
The lines are not paralell. I will attempt to attach a picture/copy of the multi-line graph...
Each of the lines represent discrete and constant (tire size in this case). I'd like the generalized equation to address the tire size as a variable.
Yeah, it would be easier if you could post a picture or just something a little more, because I'll have to explain by example... and making up an example seems more trouble than its worth.
Hopefully I have the multi-linear line graph attached for your review and comment on a generalized equation for all parameters.
Fred
Okay, so hopefully I am reading the graph right. My thoughts on this would be to read off the slopes of each line of the graph and correlate them to the tire width given for each line.
By quickly reading the graph I come up with these numbers and then looked for a relationship between them.
Tire Width(mm) vs Pressure-Load Slope (psi/kg):
[tex]37mm \longrightarrow {50psi \over 50kg}[/tex]
[tex]32mm \longrightarrow {50psi \over 40kg}[/tex]
[tex]28mm \longrightarrow {90psi \over 55kg}[/tex]
[tex]25mm \longrightarrow {130psi \over 65kg}[/tex]
[tex]20mm \longrightarrow {110psi \over 40kg}[/tex]
There are many relationships we could draw from these numbers, since the slopes aren't exact, it doesn't matter too much what you pick. I had Calc do a couple of different ones for me.
http://img522.imageshack.us/img522/4997/testzan.jpg
http://img4.imageshack.us/img4/8683/testtfv.jpg
The slopes are defined in terms of your original (x,y) coordinates, and the z (or x on my axis) is the width variable.
