Equation of a rotated parabola knowing only 3pts the equation has to satisfy
  • Context: Graduate
  • Thread starter Thread starter arpace
    Parabola
The discussion revolves around determining the equation of a rotated parabola given three specific points, with particular emphasis on the vertex and the symmetry of the parabola. Participants explore methods to derive the parabola's equation and its relation to quadratic bezier curves.
  • One participant seeks help to find the equation of a rotated parabola using three points, with the second point designated as the vertex.
  • Another participant suggests simplifying the problem by changing coordinates to place the vertex at (0,0) and hints at the general form of a parabola.
  • It is noted that while a unique parabola with a vertical axis can be determined from three points, there are infinitely many parabolas with other axes that can also pass through those points.
  • A participant speculates that the focus and directrix may be positioned at (0,p) and (0,-p) respectively, before being rotated.
  • One participant questions the feasibility of determining the rotation angle without knowing the tangent or axis of symmetry, given the unequal distances of the points from the vertex.
  • Another participant suggests using algebraic methods and symmetry properties of parabolas to approach the problem, despite being unable to provide detailed calculations at the moment.
  • Two additional posts inquire about calculating the equation of a parabola with a horizontal directrix using three specific points, indicating a related but distinct problem.
Participants express differing views on the feasibility of determining the equation of a rotated parabola from three points, with some asserting that it is not possible while others propose various methods and approaches. The discussion remains unresolved regarding the best method to achieve the desired outcome.
There are limitations regarding the assumptions made about the positioning of the focus and directrix, as well as the implications of symmetry in the context of the problem. The discussion does not resolve the mathematical steps necessary to derive the parabola's equation.
arpace
I am trying to determine the tangent of the vertex and the axis of symmetry of a rotated parabola, not knowing the equation of the parabola, and only knowing 3pts the equation has to satisfy.
Can anyone help out with this? I have three points, the second is always the vertex, and pt1 and point 2 are on opposite sides of the parabola; yet, they are unequal in distance from the vertex.
for example:
pt1 is something like 1,2
pt2 , the vertex, is 2,8
pt3, is something like 9,7
I already know the math to get tangent, I just need the process to find the equations of the parabola that is rotated knowing only three points.
This relates to quadratic bezier curves cause it will enable me to find the control point with some additional steps; it is just getting over this hurdle that bites.
Mathematics news on Phys.org
Welcome to PF!
Hi arpace ! Welcome to PF! :smile:
Hint: first, simplify it by changing coordinates so that the vertex is at (0,0).
Then you know the equation for a parabola with vertex (0,0) must be ax + by = … ? :smile:
In general, you can't. Given any 3 points, there exist a unique parabola with vertical axis of symmetry passing through those 3 points. There exist an infinite number of parabolas with other axes passing through those same three points.
^ I think the TC may have implicitly implied that the focus and directrix are positioned at
(0,p) and (0,-p) respectively, and then rotated from there.
I know that I would have to rotate it back to 0 degrees; yet, in order to do that don't you need to know either the tangent or the axis of symmetry to find the degree it needs to be rotated by?
The second point is always the vertex; yet, the points 1 and 3 are not an equal distance from the vertex; thus, this is where my hard time starts.
If it is not possible, then is there another way to determine the control point for a quadratic bezier curve, knowing the same information?
Try brute algebra force? That's my only suggestion.
Observe that for a parabola symetric between the Y axis (I forget what that's called) for every point, (x,y,) there is a corrisponding point, (-x,y), such as that (x,y) and (-x,y) are equal in distance to the y-axis (the point x=0.) When rotated, each point must still contain this symetry. You could probably use this fact in tandem with some serious trig to figure it out (I'd see what I could do, but I'm at work, I can't be jotting down equations willy-nilly. =p)
How do i calculate the equation of a parabola with a horizontal directrix given three random points along the line. I tried to translate the graph around the origin but that still didnt work. The points are (1/2,6), (3/2,16), (-3/2,-2).
A parabola with horizontal directrix has vertical axis of symmetry and so is of the form y= ax2+ bx+ c. Put the x and y values of the three points into that equation and solve for a, b, and c.
11K
  • · Replies 16 ·
67K
30K
11K
