Equation of accelerated motion in GR
The discussion focuses on the integration of the geodesic equation in General Relativity (GR) for accelerated motion, specifically in flat Minkowski space. The equation of motion is presented as d^2x^\mu/d\tau^2 = a^\mu, where a^\mu is a constant vector. The forum participants clarify that while one can integrate this equation to find x^\mu = (1/2) a^\mu \tau^2, maintaining constant proper acceleration is not feasible. Instead, they emphasize that the squared magnitude of the 4-acceleration A_\mu A^\mu can remain constant, leading to a solution involving hyperbolic functions for the 4-velocity and position.
  • Understanding of the geodesic equation in General Relativity
  • Familiarity with Minkowski space and its properties
  • Knowledge of 4-vectors and their derivatives
  • Basic proficiency in solving differential equations
  • Study the implications of constant proper acceleration in General Relativity
  • Learn about the mathematical foundations of hyperbolic functions in physics
  • Explore numerical methods for simulating motion in curved spacetime
  • Investigate matrix transformations for arbitrary acceleration directions in GR
This discussion is beneficial for students and researchers in physics, particularly those focusing on General Relativity, numerical simulations of motion, and the mathematical aspects of accelerated motion in spacetime.
Decibit
Hello forum members,
I decided to post in the homework section because my question seems very basic to me. Still I'm getting stuck with it and would appreciate any help.
I am teaching myself foundations of GR with the goal of simulating numerically some motion in flat and curved space-time. So I start with the geodesic equation
\frac{d^2x^\mu}{d\tau^2} + \Gamma^\mu_{\alpha\beta}\frac{dx^\alpha}{d\tau}\frac{dx^\beta}{d\tau} = 0
According to the forum thread: https://www.physicsforums.com/threads/accelerated-motion.118435/ one can use for constant acceleration the equation like this:
\frac{d^2x^\mu}{d\tau^2} + \Gamma^\mu_{\alpha\beta}\frac{dx^\alpha}{d\tau}\frac{dx^\beta}{d\tau} = a^\mu
where a^\mu is a constant vector with the timelike being zero.
Let us first consider flat Minkowski space so \Gamma^\mu_{\alpha\beta}=0 and the equation of motion takes the form:
\frac{d^2x^\mu}{d\tau^2} = a^\mu
At this point it almost looks like the Newton's equation. But the problem remains: how can I integrate it?
\eta=diag(-1,1,1,1)
d\tau=-\eta_{\alpha\beta}dx^\alpha dx^\beta
Greek indices run from 0 to 3, latin indices are from 1 to 3.
If I use ##\tau## as an independent variable the result doesn't make any sense
\begin{array}{l}<br /> x^i=C^i_0+C^i_1 \tau+a^i\frac{\tau^2}{2}\\<br /> x^0=C^0_0+C^0_1 \tau\end{array}
Where ## C^\mu_0## and ##C^\mu_1## are some constants. I suppose that we can fix these constants at ## C^\mu_0 = 0## , ##C^i_1=0## and ##C^0_1=1## if we start at MCRF. So the equations are further simplified to
\begin{array}{l}<br /> x^i=a^i\frac{\tau^2}{2}\\<br /> x^0=\tau\end{array}
Quick consistency check with ##a^i=(1,0,0)##.
\begin{array}{l}<br /> x^1=\frac{\tau^2}{2}\\<br /> x^0=\tau\end{array}
At ##\tau = 4## the particle has traveled 8 units of lengths and 4 units of time. As FTL travel is not possible I'm sure that I'm making a mistake. So, what is the proper way to integrate \frac{d^2x^\mu}{d\tau^2} = a^\mu (with a possibility to extend it to non-flat space-time)?
Thanks!
If a^\mu is a constant, then you can integrate immediately:
x^\mu = \frac{1}{2} a^\mu \tau^2
However, it is not actually possible for an object to maintain a constant proper acceleration. You can have a constant magnitude for the acceleration.
For a slower-than-light object, the 4-velocity satisfies: U^\mu U_\mu = c^2 (or -c^2, depending on the convention). If you take a derivative with respect to proper time, you find that: U_\mu \frac{dU^\mu}{d\tau} = 0. So the 4-acceleration A^\mu = \frac{dU^\mu}{d\tau} is always "perpendicular" to the 4-velocity. That relation can't be maintained if A^\mu is constant and U^\mu is not.
What you can do is to let the squared magnitude, A_\mu A^\mu, be constant. That means (taking a derivative with respect to proper time) that A_\mu \frac{dA^\mu}{d\tau} = 0.
Great answer! Thanks!
This was probably the whole point I was missing! So, my initial equation was wrong. No wonder that the answer didn't make sense.
Another statement you've said, namely
reminded me of something I've seen in a textbook:
Bernard Schutz: A first Course in General Relativity said:
§ 2.6: \vec{a}=\frac{d\vec{U}}{d\tau}\vec{U} \cdot \vec{a} = 0
§ 2.9 Exer. 19 A body is said to be uniformly accelerated if its acceleration four-vector \vec{a} has constant spatial direction and magnitude, say \vec{a} \cdot \vec{a} = \alpha^2 \geqslant 0
Working out through the exercise we start with
\begin{array}{l}<br /> U^\mu U_\mu = 1 \\<br /> A^\mu U_\mu = 0 \\<br /> A^\mu A_\mu = \alpha^2<br /> \end{array}
As we consider only one direction we can assume A^2=A^3=U^2=U^3=0 This allows us to express
\begin{array}{l}<br /> A^0=\frac{dU^0}{d\tau}=\alpha U^1\\<br /> A^1=\frac{dU^1}{d\tau}=\alpha U^0<br /> \end{array}
Which is a system of linear DE with constant coefficients. The solution is straightforward
\begin{array}{l}<br /> U^0=C_1 e^{\alpha \tau} + C_2 e^{-\alpha \tau}\\<br /> U^1=C_1 e^{\alpha \tau} - C_2 e^{-\alpha \tau}<br /> \end{array}
Using the MCRF initial conditions U^0(\tau=0)=1,U^1(\tau=0)=0 we get
\begin{array}{l}<br /> U^0=cosh(\alpha \tau)\\<br /> U^1=sinh(\alpha \tau)<br /> \end{array}
and after integrating these we get the solution:
\begin{array}{l}<br /> x^0=\frac{1}{\alpha}sinh(\alpha \tau)\\<br /> x^1=\frac{1}{\alpha}cosh(\alpha \tau)<br /> \end{array}
Using cosh(arcsinh(x))=\sqrt{1+x^2} it is easy to show that
x^1 = \frac{1}{\alpha} \sqrt{1+\alpha^2 {x^0}^2}
This is consistent with the derivation here http://www.physicspages.com/2011/05/25/acceleration-in-special-relativity/ So I'm quite happy now.
I think that I can figure out arbitrary acceleration direction using matrix transformations.
Thanks again for your excellent counseling!
  • · Replies 46 ·
  • · Replies 0 ·
