Solving Equations of Sets in P(E)
  • Thread starter Thread starter geoffrey159
    Sets
This discussion focuses on solving equations involving sets in the power set P(E), specifically the equations X ∪ A = B, X ∩ A = B, and X - A = B, where A and B are subsets of P(E). Participants conclude that without restrictions on A and B, these equations may not have solutions. They identify necessary conditions for solutions, including A ⊆ B, B ⊆ A, and A ∩ B = ∅. The minimal solutions derived are C_B(A), B, and B, with maximal solutions expressed as X = X_min ∪ G, where G belongs to the respective power sets.
  • Understanding of set theory and operations (union, intersection, difference)
  • Familiarity with power sets, denoted as P(E)
  • Knowledge of set complements, particularly C_E(A)
  • Ability to interpret and construct Venn diagrams for set relations
  • Study the properties of power sets and their applications in set theory
  • Learn about set operations and their implications in mathematical proofs
  • Explore the concept of set complements and alternative notations
  • Practice solving set equations with varying conditions and restrictions
Mathematics students, educators, and anyone interested in advanced set theory and its applications in problem-solving.
geoffrey159
Let ##A,B \in {\cal P}(E)##. Solve in ##{\cal P}(E)## the following equations:
  1. ##X\cup A = B##
  2. ##X\cap A = B##
  3. ##X - A = B##
  1. We have ##A\cup B = (A\cup X)\cup A = A\cup X = B##. So ##A\subset B## and the solution cannot be less than ## C_B(A) ##. So ## X = C_B(A) \cup G,\ G\in{\cal P}(A) ##
  2. We have ##A\cap B = A\cap X = B ##. So ##B\subset A## and the solution cannot be less than ##B##. So ## X = B \cup G,\ G\in{\cal P}(C_E(A))##
  3. We have ##A\cap B = \emptyset## and ## A\cup B = A\cup X##. So the solution can't be less than ##B##. Finally, ##X = B\cup G,\ G\in{\cal P}(A) ##
Is it correct ?
  1. ##X\cup A = B##
  2. ##X\cap A = B##
  3. ##X - A = B##
Is it correct ?
These equations are impossible if there are no restrictions on ##A## and ##B##. In other words, it is easy to give examples of ##A, B## in which the equations cannot possibly hold, no matter how you try to choose ##X##.
Draw some Venn diagrams and see this for yourself.
Would you mind sharing your counterexamples for the 3 different cases? Assuming ##A\subset B## for q1, ## B\subset A## for q2, ##A\cap B =\emptyset ## for q3.
No, I said that without some restrictions on ##A## and ##B## you can find cases where they are impossible.
Naturally, if you make some additional assumptions about ##A## and ##B## you CAN find solutions. It is just that as originally stated (with no restrictions on ##A,B##) it may not always be possible to have any ##X##. In other words, you either copied down the question incorrectly, or you were given a trick question.
Oh I see what you mean, I have been sloppy in my proof. In each cases, I assumed ##X## was a solution. With that assumption, I found restrictions for each cases, which are:
  1. ##A\subset B##
  2. ##B\subset A##
  3. ##A\cap B=\emptyset##.
So that outside these restrictions, there aren't any solution. Then I drew a diagram to find a minimal solution ##X_{\text{min}}## which are:
  1. ##C_B(A)##
  2. ##B##
  3. ##B##
Finally, I tried to find a 'maximal' solution ##X = X_{\text{min}} \cup G##. In each case, it has to be true that ##G## belongs to
  1. ##{\cal P}(A)##
  2. ##{\cal P}(C_E(A))##
  3. ##{\cal P}(A)##
Is it ok then ?
  1. ##A\subset B##
  2. ##B\subset A##
  1. ##C_B(A)##
  2. ##B##
  3. ##B##
  1. ##{\cal P}(A)##
  3. ##{\cal P}(A)##
Is it ok then ?
I have no idea what ##C_E (A)## means.
##C_E(A) = \{ x \in E : x\notin A\}##
Ray Vickson said:
When did the notation change? I have always seen, for the complement in the whole set ##E##, either ##A^c##, ##\bar{A}## or ##A^{\prime}##, and for the complement of ##A## in ##B## just ##B-A## or ##B\backslash A##. See, eg.,
http://www.rapidtables.com/math/symbols/Set_Symbols.htm or
http://www.mathwords.com/s/set_subtraction.htm .
Yes, I am more familiar with ##B - A## or ##B \backslash A##. I'm not sure why the author of the text in use in this thread felt the need to come up with new notation when there was existing notation that was clearer.
Sorry about this, I didn't know it wasn't an international notation !
