Graduate Equilibrium in system of non-linear difference equations
This discussion focuses on finding equilibrium solutions for a system of non-linear difference equations. The user presents a specific system involving variables \(X_j[n]\), \(X_a[n]\), \(N[n]\), and \(H[n]\), defined by a mapping \(f\) on \(\mathbb{R}^4\). The equilibrium points correspond to fixed points of the function \(f\), which can be calculated analytically or using numerical methods such as Newton's method. The discussion emphasizes the importance of understanding discrete-time dynamical systems for analyzing such equations.
  • Understanding of non-linear difference equations
  • Familiarity with fixed points and equilibrium solutions
  • Knowledge of numerical methods, particularly Newton's method
  • Basic concepts of discrete-time dynamical systems
  • Study the principles of non-linear difference equations
  • Learn about fixed point theory in dynamical systems
  • Explore numerical methods for solving equations, focusing on Newton's method
  • Review discrete-time dynamical systems and iterated maps
Researchers, mathematicians, and students interested in discrete-time dynamical systems, particularly those analyzing non-linear difference equations and their equilibrium solutions.
math4everyone
I have a little question. I want to know if there is a process in which I can find equilibrium solutions to some system of difference equations. For example, if I have something crazy like
$$\begin{cases} x[n+1]=(x[n])^2y[n]+z[n]e^{-ax[n]} \\
y[n+1]= z[n]x[n]+x[n+1]y[n+1]\\
z[n+1]= \frac{x[n]}{1+x[n]}
\end{cases}$$
I would like to know how to calculate equilibrium points when $$n \rightarrow \infty$$
Using the equation for ##x_{n+1}## first write ##y_{n+1}## as a function of ##(x_n,y_n,z_n)##. (So, eliminate ##x_{n+1}##). After this, the right-hand side of your system defines a function ##f## on ##\mathbb{R}^3##, as
\begin{bmatrix}
x_{n+1}\\
y_{n+1}\\
z_{n+1}
\end{bmatrix}
= f(x_n,y_n,z_n).
Your equilibrium points are the fixed points of ##f##.
Likes Greg Bernhardt
\begin{bmatrix}
x_{n+1}\\
y_{n+1}\\
z_{n+1}
\end{bmatrix}
= f(x_n,y_n,z_n).
Thanks for the reply, but this was just an example. I apologize for not stating the real problem.The real system of difference equations I have is the following
\begin{cases}
X_j [n+1] = (1-m_j - \theta - \delta N[n])X_j[n]+\alpha X_a[n] e^{-\beta X_a [n]} \\
X_a[n+1]=(1-m_a-H[n]-\delta N[n])X_a[n] + \theta X_j[n]\\
N[n+1] = \frac{\gamma K X_a [n]}{K+\gamma X_a[n]} \\
H[n+1] = q \left( \frac{a(P_f q X_a [n]-C_f - \pi \omega_\tau)}{1+b(P_f q X_a [n]-C_f - \pi \omega_\tau)}+E_{min} \right)
\end{cases}
I am really new to this topic, so I don't fully understand what I have to do.
It's the same principle: This system corresponds to a mapping ##f## on (a domain in) ##\mathbb{R}^4## that takes as inputs the state ##(X_j[n], X_a[n], N[n], H[n])## at the (discrete) time ##n \in \mathbb{Z}_+## and produces the state
\begin{bmatrix}
X_j[n+1]\\
X_a[n+1]\\
N[n+1]\\
H[n+1]
\end{bmatrix}
= f(X_j[n], X_a[n], N[n], H[n])
at time ##n + 1##. A stationary solution of the difference equations then corresponds to a state that does not change in time. Such a state is precisely a fixed point of ##f##. I did not calculate the fixed points myself, that is up to you. Sometimes they can be found analytically, but sometimes you need to resort to numerical root finders such as Newton's (and Newton-like) method(s).
This and related topics (such as stability determination of the stationary solutions) are typically treated in courses and books on discrete-time dynamical systems ("iterated maps").
Likes jim mcnamara
  • · Replies 0 ·
