Equivalence between an injection and a surjection
8 replies · 2K views
mtayab1994
Let A and B be two sets.
Prove that there exists a injection from A to B if and only if there exists a surjection from B to A
I did one implication which is we suppose that f: B→A is a surjection.
Then by definition of a surjection: [tex]\forall a\in A,\exists b\in B/f(b)=a[/tex]
Then for each a in A we consider the nonempty set [tex]f^{-1}(a)[/tex]
and I let an arbitrary b in [tex]f^{-1}(a)[/tex] and then I defined the function:
g: A→B so we get g(a)=b for our choice of b in [tex]f^{-1}(a)[/tex] and this is injective, because f was a function that we established earlier so if we take b1 in [tex]f^{-1}(a_{1})[/tex]
and b2 in [tex]f^{-1}(a_{2})[/tex] then it's simple to see that b1≠b2, but if they were equal then by definition:
a1=f(b1)=f(b2)=a2. So therefore g is injective. Is this correct so far?
Supose A = {1,2,3}, B = {1,2,3,4,5}. Then f(n) = n for n = 1,2,3 is an injection form A to B. But there is no surjection from B to A.
[Edit, added later]: You can safely ignore this post as noted below.
Really? :confused:
Maybe I'm misunderstanding. Let ##g:B\to A, x\mapsto\left\{\begin{matrix} 1 & \text{if } x\in\{1,4,5\} \\ 2 & \text{if } x=2 \\ 3 & \text{if } x=3\end{matrix}\right.##. Isn't this a surjection? Its image is clearly equal to its codomain, right?
Take [itex]f: B \to A[/itex] with [itex]f(x) = x[/itex] for [itex]x \in \{1, 2, 3\}[/itex] and [itex]f(4)[/itex] and [itex]f(5)[/itex] arbitrary. Then f is a surjection (for every [itex]a \in A[/itex] there exists at least one [itex]b \in B[/itex] such that [itex]f(b) = a[/itex].
What does not exist is an injection from B to A.
Mandelbroth said:
Really? :confused:
Yes. Sorry, I was thinking bijection when I was reading surjection. :redface:
So the first implication of the proof is fine right?
At this point you could note that if [itex]g(a) \in f^{-1}(\{a\})[/itex] then by definition [itex]f(g(a)) = a[/itex], and the proof that g is injective is then straightforward.
This is correct.
A point of notation: [itex]f^{-1}(\{a\}) \subset B[/itex] is the pre-image of the singleton subset [itex]\{a\} \subset A[/itex], which is well-defined even if f is not a bijection. This must be distinguished from [itex]f^{-1}(a) \in B[/itex], which is the image of [itex]a \in A[/itex] under the inverse of f, which is not well-defined unless f is a bijection.
This is correct.
Thank you every much for the information I really appreciate it .
