A.T. said:
DrGreg said:
"Gravitational time dilation" really has nothing to do with gravity, it's due to the proper acceleration of the observer.
Doesn't a free falling clock in the center of the mass run slower than a free falling clock far away, regardless any proper acceleration?
What I said is probably a bit of an oversimplification. I'm thinking in terms of the local approximation in which the equivalence principle is valid. To be honest, I don't know the answer to that specific question.
A.T. said:
DrGreg said:
You get it for observers hovering a fixed distance above planet, you also get it for accelerating observers in the absence of any gravitational source.
I agree that "gravitational time dilation" doesn't imply a "gravitational source". But by "gravity" (as opposed to "gravitation") I usually just mean an inertial force in an accelerated frame, which we sometimes call "the force of gravity". This force alway occurs together with gravitational time dilation.
Yes, in terms of relativistic terminology the "pseudo-gravity" inside an accelerating rocket isn't "pseudo" at all, it really is "gravity".
A.T. said:
DrGreg said:
Also, to be pedantic, the "metric" is also an intrinsic property of space-time and does not depend on the observer or on the choice of coordinates. The "Rindler metric" is therefore misnamed and really ought to called "the Minkowski metric expressed in Rindler coordinates".
This puzzles me. Wouldn't an observer, moving relative to the gravitational source, observe a different, Lorentz-contracted metric? Or given two gravitational sources, moving relative to each other, wouldn't the metric created by their combined influence look different in thieir individual reference frames?
I'm referring here to the metric tensor, the 4x4 matrix of coefficients usually expressed by an equation of the form
ds2 = ... . Just as with 4-vectors, when you change coordinate systems, the values of the 16 numbers in the matrix will change, but it's still regarded as the "same" tensor, just expressed in a different coordinate system. This is just a question of terminology; the numbers change but it's still the "same entity". And if you think of the space metric inherited from the space-time metric, yes that really does change, as your decomposition of space-time into 3D space + 1D time changes.
To give an example, in flat, Euclidean 2D space, the equations
ds^2 = dx^2 + dy^2
ds^2 = dr^2 + r^2 d\theta^2
both describe the same 2D Euclidean metric.
I am being a little pedantic here, because in practice people often (though technically incorrectly) use the word "metric" to refer to a specific equation in a particular coordinate system.
