Error Calculation in Multiplication of two measurement points
brad gover
Hi All, I have a problem in calculating the thickness of a coating material inside a tube. The tubes inside diameter is measured before and after coating. The coating thickness is calculated by substracting the diameters and dividing by two to get the thickness of the coated material. The before coat diameter is 0.3949". The after coat diameter is 0.3893". The measurement error's standard deviation is 0.00017". I need to calculate the coating thickness value and its associated error.
Coating Thickness = (Before Coat Dia. - After Coat Dia.)/2
I am thinking the thickness without error = (0.3949 - 0.3893)/2 = 0.0028"
My error for each measurement would be measured value +/- 3 x the Standard Deviation Error.
For uncoated = 0.3949" +/- 0.00051"
For Coated = 0.3893" +/- 0.00051
The minimum thickness = (0.3949 - .00051) - (0.3893 + 0.00051) = 0.00458"
The maximum thickness = (0.3949 + 0.00051) - (0.3893 - .00051) = 0.00662"
Error Thickness = (.00662 - 0.00458)/2 = 0.00102"
Coating Thickness = 0.0028" +/- 0.00102"?
There are standard formulas for doing this. Look up 'propagation of errors' in Bevington or some similar book.
