Errors and significant figures
  • Thread starter Thread starter Zayan
Zayan
L= 5.7±0.1
B=3.4±0.2
Find area with error limits.
∆A/A=∆L/L+ ∆B/B
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19.
For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as the mean value? Which one?
I'm not sure I know the expected answer, but I'd make the following observation. With that data, the area is between 17.92 and 20.88 units. That's definitely a range of nearly 3 units. It seems valid to say ##\pm 1.5##.
PeroK said:
I'm not sure I know the expected answer, but I'd make the following observation. With that data, the area is between 17.92 and 20.88 units. That's definitely a range of 3 units. It seems valid to
That's true. But I had studied that we round off to the same no. of significant figures as the data given. I had also studied that we keep decimal places same as the original data. Idk I'm confused lol
Zayan said:
That's true. But I had studied that we round off to the same no. of significant figures as the data given. Idk I'm confused lol
My mathematical instinct is satisfied by ##19.4 \pm 1.5##.
In this case, reducing the answer to ##19## plus or minus whatever doesn't make much sense.
Say the problem involved buying stuff and you had to have enough. You'd definitely want 21 units and not 20 or 20.5. If 21 is not enough, then the given data was wrong!
That's what error bars are for, IMHO.
PS 20.5 is not an upper limit for the area. It would have to be ##19 \pm 2##, assuming the error must be symmetric.
Then doesn't it add MORE uncertainty than there is? According to that logic shouldn't it be 19.4±1.48 if we're being SUPER precise.
Also, I'm not sure whether we should be assuming the mean value to be the arithmetic mean of the upper and lower limits. So rounding off to the original data seems fair.
The idea behind error propagation is to calculate the uncertainty in the result. Once you know the uncertainty, it tells you where to round to. The rules for sig figs are just general rules of thumb to estimate how the uncertainty propagates without having to do a proper analysis of error propagation. (That means don't use them for this problem.)
Are you sure you're calculating the uncertainty correctly? When you have a formula like ##A = LB##, the uncertainty is usually estimated using
$$\left(\frac{\Delta A}{A}\right)^2 = \left(\frac{\Delta L}{L}\right)^2 + \left(\frac{\Delta B}{B}\right)^2.$$
Area is L*B.
A=L*B
Take natural log on both sides,
lnA= lnL+lnB
Take differential on both sides,
(1/A)dA= (1/L)dL + (1/B)dB.
Thus giving,
∆A/A=∆L/L+ ∆B/B
The way to write the answer formally to ##N## sig figs is using powers of ten in the form ##~\text{X.XXX}\times 10^n~## with ##N-1## digits to the right of the decimal. So 19.38 to two sig figs would be ##1.9\times 10^1##.
If you have an uncertainty, you write it as a number to the same power of 10, in this case ##0.148\times 10^1.##
When you put the two together, the uncertainty would normally have one sig less than the answer. I say "normally" because there is an exception: if there is a "1" to the left of the decimal the uncertainty is written to the same number of sig-figs as the answer. That's because the dropped sig fig constitutes a considerable percentage of the answer.
So here you would write ##(1.9 \pm 0.15)\times 10^1## which more conventionally is ##19\pm 1.5.##
As an additional example, if you changed B to 5.3 keeping everything else the same,
The area is ##30.21\rightarrow 3.0\times10^1##
the uncertainty is ##1.67\rightarrow 0.167\times10^1##
and put together you get ##(3.0\pm 0.2)\times10^1##, conventionally written as ##30\pm 2.##
It's not a question of being precise. It's a question of the area definitely lying within the range given.
I had the same question so I looked up some sites and found this
http://www.geol.lsu.edu/jlorenzo/geophysics/uncertainties/Uncertaintiespart2.html
that features both methods.
Let's say that I had some data with 2 significant figures, and 1 decimal place, eg, 9.2,9.6, etc. Now I calculate the mean value and it comes out to be 9.3. Now since it is the same significant figures, I don't round off. But let's say the error comes out as 0.12. This has 2 significant figures, but it has one extra decimal place. Should I write the answer as 9.3±0.12 OR 9.3±0.1.
As I said, my instinct is that the true area must lie within the given range. In this case, area could be 20.8, which is not ## 19\pm 1.5##.
This is what happened with the blinds for my bedroom window. They were supposed to be whatever ##\pm 0.5## cm. But, they were +1cm more than I specified and they didn't fit and I had to send them back.
It's commercially useless in that context to have an actual size outside the error range.
Don't go into the home furnishings business is my advice.
As you see, the formal way of estimating the error agrees with your instinct and that is why I posted it.
And my advice to your home furnishings supplier is "measure twice, cut once." :oldsmile:
The mean value of 9.2 and 9.6 is halfway between at 9.4, not 9.3. If the error comes out as 0.12 you should write this as 9.4±0.1. However, if I were making these measurements, I would be concerned with the difference between the two values which is considerably larger than my estimated error and make one more measurement to see where it falls. You should understand, that what follows the ##~\pm~## sign is only an estimate. The idea is that if your measurements follow a normal distribution about the mean, the uncertainty calculated using the standard deviations expression $$\frac{\Delta A}{A}=\sqrt{\left(\frac{\Delta L}{L}\right)^2+\left( \frac{\Delta B}{B}\right)^2}$$ indicates that if you make repeated measurements of the same quantity, about 68% of the values will be within the ##~\pm~## range.
I also said "etc", implying there are more measurements that I didn't type.
Zayan said:
Area is L*B.
A=L*B
lnA= lnL+lnB
Thus giving,
∆A/A=∆L/L+ ∆B/B
It depends what you mean by the uncertainty.
In many contexts you want the statistical uncertainty, i.e. standard deviation. If X and Y are independent, ##(\frac{\sigma(XY)}{E (XY)})^2=(\frac{\sigma X\sigma Y}{E(X)E(Y)})^2+(\frac{\sigma X}{E(X)})^2+(\frac{\sigma Y}{E(Y)})^2##.
For small variances we can ignore the first term on the right, giving @vela's version.
An engineer often cares more about tolerances. If the Deltas are the maximum errors then your formula is the one to use.
If that's the convention used in your class then that's what you do.
That is confusing, but when expressing a result in the form ##x \pm \Delta x## both ##x## and ##\Delta x## should be rounded to the same number of decimal places.
So, your instructor would want either ##19.4 \pm 1.5## or ##19 \pm 1##.
When I was a practicing EE, none of this ever made sense to me. These problems rarely mention the probability distribution of the data or what the user cares about. If you have a flat density and have to never exceed some value, you'll care about a really different result than if everything is assumed and reported as gaussian, for example.
I think there are many unstated assumptions here, which cloud the reported result. This is a "word problem" not an equation. You do the math on the data set first, then report what the user needs.
Sorry, I know this isn't a helpful response for your problem. Except to say, expect confusion in the future. I don't think there are simple rules that are useful IRL.
Likes PeroK, Herman Trivilino and haruspex
Zayan said:
Homework Statement: L= 5.7±0.1
B=3.4±0.2
Relevant Equations: ∆A/A=∆L/L+ ∆B/B
Part of the problem is that there are two common systems which many (most) conflate.
Either imply the uncertainty from the number of significant figures or state the uncertainty.
"5.7” implies ##5.7\pm 0.05##. Here we are given ##5.7\pm 0.1##, so we should take both numbers as exact.
Having obtained ##19.38\pm 1.48##, you could validly leave it at that (it makes no undue claim regarding precision) but you would also be justified in simplifying it to ##19.4\pm 1.5##. There is certainly no need to trim the digits further, and it would throw away too much information.
Likes PeroK and Herman Trivilino
That is the issue, so the "correct" answer is a result of however well the instructor or textbook authors understand the issue.
The poor student is often left confused.
Agreed. When rounding off to the so-called appropriate number of sig figs what you are really saying is "Don't worry about the uncertainty because I have eliminated it by rounding".
In my opinion instructors get carried away by over-emphasizing rounding to the "correct" number of sig figs. Certainly we don't want students using too many or two few, but there should either be some leniency allowed or an insistence on a specific number of sig figs for all textbook-type problems. When reporting lab results the appropriate number of sig figs used in results can be stated clearly. This gives the instructor the opportunity to again discuss the appropriate use of sig figs and why it's important.
Years ago I read an interesting journal article about this. The author had researched the amount of space in introductory textbooks devoted to the topic of sig figs. Turns out in years prior to the early 1970's there was no discussion of the issue. After that the amount of space devoted to the discussion quickly increased?
What happened?
Calculators!
Instructors were exasperated by students copying their calculator displays, reporting 7 or 8 sig figs when only 3 or 4 were justified.
Zayan said:
Area is L*B.
A=L*B
lnA= lnL+lnB
Thus giving,
∆A/A=∆L/L+ ∆B/B
This is only correct if you view ##\Delta L## and ##\Delta B## as fixed numbers. In a setting where you have estimated errors, it is more appropriate to view them as statistical distributions, normally Gaussian distributions. If these are uncorrelated then you would obtain the result with the square root of the sum of the squares. If they are correlated (or indeed anti-correlated!) you will obtain a different expectation for the error in ##A##.
Likes DaveE and berkeman
Just a follow-up on the equation I gave in post #18…
I felt it was surprisingly inelegant, then I realised it could be rewritten as:
##f(XY)=f(X)f(Y)##
where ##f(X)=\frac{E(X^2)}{E(X)^2}##.
