Estimating diffraction pattern width from uncertainty principle for 50eV electrons
8 replies · 6K views · last reply
throneoo
A beam of 50eV electrons travel in the x direction towards a slit of width 6 micro metres which is parallel to the y direction. The diffraction pattern is observed on a screen 2 metres away.
Use the Heisenberg uncertainty principle to estimate the minimum uncertainty in the y-component of the electrons' momentum after passing through the slit . Use it to estimate the width of the pattern produced on the screen
dsinθ=nλ
ΔyΔP≥h/4π
λ=h/sqrt(2mE)=h/p
Width=2Dtanθ
The first thing I did was to find out the wavelength of the electrons .
Then , I assumed the electron's vertical positions are confined within the slit , so Δy=d
This is where I got stuck .
First of all , I'm not sure what's meant by the width of the pattern . The distance between the 1st order fringes / max. order fringes ? if it's the latter , since d>>λ , the max order n I obtained was 34570 , and the width would be 3106 m , which is ridiculously large . and the HUP would be of no use at all in both cases,since all i need is the angle.
Second of all , I'm not sure what ΔyΔP is limited to . I'm still new to this and I've seen variants of the formula with different limits :h/4π, h/2π , h , h/2 ...
which makes me wonder if the limits are derived and vary from situations to situations , with h/4π being the lowest limit in theory .
Any help would be appreciated
dsinθ=nλ
Let n = 1 and approximate sinθ = θ
ΔyΔP≥h/4π
There is no hard & fast rule. For this problem, go with ΔyΔpy ≥ h
[/quote]
Correct. This is a vital assumption.
The width of the pattern is the distance between the two first minima.
Hint: assume the uncertainty corresponds to the distance from the center to a first minimum.
Start with ΔyΔpy = h
Relate Δpy to m and vy. Pretty obvious ...
Relate wavelength to the x-axis speed (I would leave out numbers. Call it vx). I believe you already did this.
You can now relate Δy, Δvy, vx and λ.
By geometry you can also relate vy and vx to your angle θ.
Finally you can relate θ to λ and Δy which is the formula derived by wave theory (except for the sinθ = θ approximation.
rude man said:
ΔyΔpy ≥ h
thanks for the guidance. but i still cannot convince myself about this. how do we find out what the constant is?
What constant are you talking about? h? You're supposed to START with the Heisenberg uncertainty principle which is defined in terms of the known constant h (as Max Planck formulated it well before Heisenberg's 1927 relation).
The original equation was ##\Delta x \Delta p \geq h##
But fermilab (?) reported back uncertainties ##\Delta x \Delta p \geq \hbar/2 = h/4pi## I'm pretty sure it was fermilab, and I'm pretty sure it was hbar and not h, but my uncertainty must be greater than... cutting the circle here.
ok so apparently you want \hbar and not \bar{h} in latex
Heisenberg posited the uncertainty products to be "of the order of h". So whether yiou go with h or h-bar or h/2 makes no difference.
does θ here refer to the angle subtended by the two minima ?
because I normally use θ as the angle between the horizontal axis and the fringes
then in that case , dsinθ=λ/2 , which is the path difference between the destructively interfering waves .
anyway , using the small angle approximation and ΔyΔpy = h,
px=h/λ
2θ=Φ=λ/Δy = Δpy / px , where θ is the angle between the horizontal axis and one of the first minima and Φ is that between the two first minima
the 'width' = 2Dθ = DΦ , where D is the distance between the screen and the slit
θ is the angle between the center of the screen and either firtst minimum on that screen. The formula for that is d sinθ = λ, not what you wrote,
where d is the width of the slit; in your case d = Δy.
Below you state " ... where θ is the angle between the horizontal axis and one of the first minima" which is the same angle θ as mine.
px=h/λ
Make that θ = λ/Δy = Δpy / px and you've got a deal.
Everything else looks fine.
