Euclidian topology ang cofinite topology
  • Thread starter Thread starter lindita
    Topology
lindita
please can you help me to prove this exercise;
Prove that:
the Euclidean topology R is finer than the cofinite topology on R
please answer me as faster as u can I have an exame on monday and I don't know to provethis exercise!
Consider an arbitrary open set U in the cofinite topology. U is all of R except x_1,x_2,\ldots,x_n. Given some point x \in U can you find an open interval I containing x, but included in U. That is x \in I \subseteq U where I is open in the standard Euclidean topology and U is open in the cofinite topology. (HINT: can you show that the open interval centered at x with radius \min(|x-x_1|,|x-x_2|,\ldots,|x-x_n|) works?)
It's a well-known theorem that if for every open set U in a topology T, and every point x\in U we can find some set U' such that x \in U' \subseteq U and U' is open in the topology T', then T' is finer than T.
thank you! U had helped me a lot thanks thanks
Can you help me and for this exercise please!
the function f:(X,T)->(X,T') is continuous
the function f:(X,T')->(X,T) is open
{T is the Euclidean topology,T' is cofinite topology}
[the function f maybe is the identity function id but I am not sure]
I'm assuming that you're asked to prove the two statements.
If f is the identity function then you're just restating the result in the OP. That f:(X,T)->(X,T') is continuous means that for every set U open in T', the set f^{-1}(U) = U is open in T. Hence this is equivalent to "if U is open in T', then U is open in T" which is just stating that T is finer than T'. The other statement is shown in exactly the same way.
If f is an arbitrary function then the result is not true because for every y \in X we can let f_y : (X,T') \to (X,T) be the constant function f(x) = y so f(X) = \{y\} is open according to your second statement. Since every one-element set is open T is the discrete topology, but the Euclidean topology is different from the discrete topology (unless of course X consists solely of isolated points).
Thank you!
