Euler-Lagrange equations for geodesics with arbitrary parameter
  • Context: Graduate
  • Thread starter Thread starter noamriemer
    General
1 reply · 2K views
noamriemer
Hello! I ask this question in this forum because I wish to be given a general explanation.
Hope it is OK
given this metric:
[itex]ds^2= \frac {dt^2} {t^2}- \frac{dx^2} {t^2}[/itex]
I wish to calculate the geodesics.
[itex]S=\int{ \frac {d} {d\lambda} \sqrt{\frac {1} {t^2} \frac {dt^2} {d\lambda^2}- \frac{1} {t^2} \frac {dx^2} {d\lambda^2}}}[/itex]
But [itex]\lambda[/itex] here, is any parameter I choose. Therefore, L does not depend on it (right? )
So now I want to use E-L equations:
[itex]\frac {d}{dλ}\frac {∂L}{∂\dot t}=\frac {\partial L} {∂t}, <br /> \frac {d} {dλ}\frac {∂L} {∂\dot x} =\frac {\partial L} {∂x}[/itex]
When [itex]\dot t[/itex] refers to [itex]\frac {dt} {d\lambda}[/itex] etc.
But here I get confused:
What does L depend on?
I'll continue my solution:
[itex]\frac {d} {dλ} 0.5 ({{\frac {{\dot t}^2} {t^2}-\frac {{\dot x}^2} {t^2}}})^{-0.5} 2 \frac {\dot t} {t^2}= \frac {\partial L} {\partial x}[/itex]
As I stated, L does not depend on lambda, and so:
[itex]\frac {d} {d\lambda} {[\frac {\dot t} {t^2}]}^2 = \frac {{\dot t}^2-{\dot x}^2} {t^3}[/itex]
So how am I supposed to derive this? Do I add another dot?
[itex]\frac {d} {d\lambda} \dot t = \ddot t[/itex] ? and do I refer to it as an operator? Meaning- [itex]\ddot t = {\dot t}^2?[/itex]
How do I continue? These calculations on classical mechanics were so trivial to me- but for some reason I get lost in here...
Thank you!
noamriemer, There are several different equivalent Lagrangians that may be used to calculate the geodesics. The easiest, I believe, is to use L = gμν dxμ/ds dxν/ds. This eliminates dealing with the square root. So for your case, L = t-2 (dt/ds)2 - t-2 (dx/ds)2. You let t' = dt/ds and x' = dx/ds for short, and write the equations as, for example, d/ds(∂L/∂t') - ∂L/∂t = 0.
