Euler's Method of Numerical Approximations
Euler's Method of Numerical Approximations is implemented in MATLAB to solve ordinary differential equations. The algorithm involves defining a function f(t,y), inputting initial values t0 and y0, and iterating through a specified number of steps using a defined step size h. A common issue arises when the function is not recalculated in each iteration, leading to incorrect results. The solution involves using inline functions to dynamically evaluate f(t,y) within the loop, ensuring accurate calculations at each step.
  • Understanding of Euler's Method for numerical approximations
  • Familiarity with MATLAB programming
  • Knowledge of inline functions in MATLAB
  • Basic concepts of ordinary differential equations
  • Implement and test MATLAB inline functions for dynamic evaluations
  • Explore error analysis in numerical methods
  • Learn about higher-order numerical methods like Runge-Kutta
  • Study the impact of step size on the accuracy of numerical approximations
Students and professionals in mathematics, engineering, and computer science who are working with numerical methods for solving differential equations, particularly those using MATLAB for simulations.
kishtik
Hello,
For Euler's Method of Numerical Approximations, my book (Boyce&DiPrima)
gives this algorithm:
Step 1: define f(t,y)
Step 2: input initial values t0 and y0
Step 3: input step size h and number of steps n
Step 4: output t0 and y0
Step 5: for j from 1 to n do
Step 6: k1 = f(t,y)
y = y + h*k1
t = t + h
Step 7: output t and y
Step 8: end
I tried this on Matlab. My code was:
t=input('Enter t0:');
y=input('Enter y0:');
h=input('Enter step size h:');
n=input('Enter number of steps n:');
k1=input('Define f(t,y):');
result=zeros(n,2);
result(1)=t;
result(1,2)=y;
for j=[2:n+1]
k=k1;
y=y+k*h;
t=t+h;
result(j,1)=t;
result(j,2)=y;
end
disp(' t y');
disp(result);
But I realize that my program calculates k1 only for the initial values... How can I change it so that k1 is actually calculated in every turn of for loop?
Thanks.
You need to evaluate k = f(t,y) INSIDE the for loop. This way each time you change t and y, you will get a new value for k.
result=zeros(n,2);
result(1)=t;
result(1,2)=y;
for j=[2:n+1]
k=k1;
k = f(t,y)
y=y+k*h;
t=t+h;
result(j,1)=t;
result(j,2)=y;
end
disp(' t y');
disp(result);
Of course, but the value of k1 is evaluated and assigned at the line
before the loop and the information about the function which should be used to evaluate k's is lost... How can I change it so that it actually evaluates k in the loop using the input k1 as a formula rather than the first of k's?
(Edit: 100th post btw.)
Ok, I thought your input k1 was just the initial value, but you're saying
is supposed to take in a symbolic function f(t,y)?
Yes, and that symbolic expression should be used to compute the next k's in every turn of the loop.
Ok, I think you want to use inline functions. If you use
and enter something like 't^3+4-5*y' with the ' ', then after that put
f = inline(k1);
and it should define f(t,y) = t^3+4-5*y. Then replace k=k1 with k=f(t,y) insinde your loop. I think that will do what you want.
Code:
f = inline(k1);
result=zeros(n,2);
result(1)=t;
result(1,2)=y;
for j=[2:n+1]
k=f(t,y);
y=y+k*h;
t=t+h;
result(j,1)=t;
result(j,2)=y;
end
disp(' t y');
disp(result);
Thank you! That was just what I was looking for. But now I have another problem...
I modified the code to:
k1=input('Define f(t,y) in single quotation marks:');
f=inline(k1,'y','t');
result=zeros(n,2);
result(1)=t;
result(1,2)=y;
for j=[2:n+1]
k=f(t,y);
y=y+k*h;
t=t+h;
result(j,1)=t;
result(j,2)=y;
end
disp(' t y');
disp(result);
And tried the example in the book(p.103) with,
t0 = 0,
y0 =1,
h=0.1,
n=4,
f(t,y)=3 + exp(-t) - (1/2)*y,
and got this out:
t _________________y
0________________1.00000000000000
0.10000000000000 1.33678794411714
0.20000000000000 1.65805675248899
0.30000000000000 1.96710763513263
0.40000000000000 2.26609371515479
but the book gave
y0 = 1
y1 = 1.3500
y2 = 1.6730
y3 = 1.9712
y4 = 2.2467
Nearly %2 error for every y. Isn't this too much for an error from rounding or "how my program is constructed" or "how my computer executes arithmetic steps"? The book says "minor variations in the last decimal place" are acceptable, but %2?
k=f(t,y);
It looks like you have defined f(y,t) and are evaluating f(t,y). So switch one of the two and it should work.
It does. :smile:
  • · Replies 18 ·
  • · Replies 0 ·
