Evaluate expression W/O Calculator
30 replies · 6K views
kscplay
Find the exact value of the following expression.
[itex]\sqrt[3]{10+6\sqrt{3}}+\sqrt[3]{10-6\sqrt{3}}[/itex]
Don't know where to start. I guess we can factor out a 2[itex]1/3[/itex] but I don't see how that would help. Any clues? Perhaps some factoring method/identity can be used? Thanks.
Let [itex]x = \sqrt[3]{10+6\sqrt{3}}+\sqrt[3]{10-6\sqrt{3}}[/itex]
Find [itex]x^3[/itex].
Maybe there are values for a & b such that
[itex]\displaystyle \left(a+b\sqrt{3}\right)^3=10+6\sqrt{3}[/itex]​
and
[itex]\displaystyle \left(a-b\sqrt{3}\right)^3=10-6\sqrt{3}[/itex]​
or something like that.
Ingenious!:cool:
ehild
Why not? You get an easily factorizable equation of form x^3+ax+b=0.
ehild
and
The answer is: a=1, b=1 .
[itex]\displaystyle \left(1\pm\sqrt{3}\right)^3=10\pm6\sqrt{3}[/itex]
ehild
No, I meant it's not really ingenious, I found it easy to see, and I'm sure it's quite easy for others to see, too. :smile:
Familiarity with the expansion of the binomial form (a+b)3 will indicate there are square terms which might help with the square root surd (in the event, it does not, but that's what led me to think of it). Combined with the fact that the two factors are conjugate surds which can be multiplied together to give an integer (a perfect cube!), it's quite easy to see that this is a quick and painless way.
Yes, you get a cubic that can be easily solved with the rational root theorem. The other solutions are complex, so the only real (integral) root is the answer.
Okay, I get the following for x3:
20-6[itex]\sqrt[3]{10+6\sqrt{3}}[/itex]-6[itex]\sqrt[3]{10-6\sqrt{3}}[/itex]
I still don't see it. Is my x3 correct? Thanks.
ehild
Could you please elaborate on that? Thanks.
Notice that x3=20-6x.
Or choose SammyS's hint...
ehild
Rewrite the equation as (x3-8)+6(x-2)=0. You can factor out x-2.
but SammyS' method is easier: [tex]\displaystyle \left(1\pm\sqrt{3}\right)^3=10\pm6\sqrt{3}[/tex]
He is the Master of Square Roots :cool:
ehild
ehild
Thanks, I get it now :) My final answer is 2. I just factored because I didn't really understand how SammyS solved for a & b.
He has got magical eyes. :smile: He just looks at an expression with roots and sees how to simplify it. It comes with long practice, I guess.
But it is worth to remember that the powers of (b±√a) are of the form A+B√a.
(b±√a)3=b3±3b2√a+3ab±a√a=b(b2+3a)±√a(3b2+a).
In this problem, a=3, b(b2+3a)=b(b2+9) =10, 3b2+a=3b2+3=6, =>b=1ehild
How would you expand this? I'm trying to solve this problem as well.
Use binomial theorem.
I'm having trouble expanding the expression; I'm not sure how to simplify it.
Post what you've done so far.
Would you multiply the expression like this?
[itex]([/itex][itex]\sqrt[3]{10+6\sqrt{3}}[/itex]+[itex]\sqrt[3]{10-6\sqrt{3}}[/itex][itex])[/itex][itex]^3[/itex]
Yes, but you're not multiplying, you're cubing. What's the expansion of the binomial (a+b)3?
(a+b)^3 = a^3+3a^2b+3ab^2+b^3
Correct?
Correct?
Correct. x^3 = (a+b)^3 = a^3+3a^2b+3ab^2+b^3
So a^3 = ?
b^3 = ?
You can add those up to a simple integer immediately.
That's the easy part, unfortunately.
Express a^2b as (a)(ab) and ab^2 as (b)(ab), so the rest of the expression becomes 3(a+b)(ab).
Can you find an expression for ab?
Use (m+n)(m-n) = m^2 - n^2 for this bit.
Now remember (a+b) = x. You'll now be able to get to a cubic equation in terms of x.
So a^3 = ?
b^3 = ?
That's easy part, unfortunately.
Will a^3+b^3 = 20?
I'll try the rest tomorrow after school. Thanks for your help.
S.R said:
Will a^3+b^3 = 20?
Yes, good. OK, till tomorrow then.
Notice that [itex]\displaystyle (10+6\sqrt{3})(10-6\sqrt{3})=(10)^2-(6\sqrt{3})^2=100-108=-8[/itex]
This will come in handy when you expand your expression out.
Yes, well, we were saving that up for tomorrow. :biggrin:
So far I have I calculated a^3+b^3 = 20 and ab = -2. I just need to figure out -6*(a+b). But I'm stuck here.
Let
[tex]a=\sqrt[3]{10+6\sqrt{3}}[/tex]
[tex]b=\sqrt[3]{10-6\sqrt{3}}[/tex]
And use the binomial theorem for expanding the cube of a sum
[tex](a+b)^3=a^3+3a^2b+3ab^2+b^3[/tex]
ughh ignore this post, I totally missed page 2 lol
That's the neat part! Leave it as -6(a+b) = -6x.
Now put everything together:
x3 = 20 - 6x
x3 + 6x - 20 = 0
Do you know how to solve cubics that have rational roots? Hint: Rational Root Theorem.
x3 = 20 - 6x
x3 + 6x - 20 = 0
I didn't notice that; thanks!
EDIT: x^3+6x-20=0
(x-2)(x^2+2x+10) = 0
The only real solution is x=2.
