Evaluating a limit as x tends to ## \infty##
  • Thread starter Raghav Gupta
    Limit
20 replies · 4K views · last reply
Raghav Gupta
$$ \lim_{x\to\infty} (\sqrt{a^2x^2 +bx + x} -ax) = $$
b/2a
b/a
2b/a
Lim x tends to infinity 1/x = 0
Taking a2x2 common from square root, we get
$$ \lim_{x\to\infty} (ax \sqrt{1+\frac{b}{a^2x}+ \frac{1}{a^2x}} -ax) = $$
Putting x as infinity we get,
ax - ax = 0
But Wolfram is showing something else
b/2a
b/a
2b/a
ax - ax = 0
Wolfram is right. You multiply something that tends to zero with something that goes to infinity. You can not conclude that the limit is zero.
Use the approximation ##\sqrt{1+\delta} = 1+0.5 \delta ## valid if δ<<1.
b/2a
b/a
2b/a
ax - ax = 0
You took the limit too soon. Instead, notice that both terms have a factor of ax, so factor that expression out so that you're taking the limit of ax * <other stuff>. What do you get now for your limit?
What is the result if a is not a positive number ?
b/2a
b/a
2b/a
ax - ax = 0
None of the possible answers listed is correct. What do you get if a > 0? What do you get if a < 0?
I get
$$ \lim_{x\to\infty} (ax( \sqrt{1+\frac{b}{a^2x}+ \frac{1}{a^2x}} -1)) $$
Now what should I do to solve it?
Can some formula, L Hopital rule etc. be applied here?
Don't know for both the cases.
It is amazing that most of the questions which I post are wrong or options are wrong. ( Test makers should verify the questions as it wastes time in exam hour.:mad:)
Okay leaving the options,
Can we say for this problem that the limit not exists?
Raghav Gupta said:
I get
##\sqrt{a^2x^2} = |ax|##
Since the limit is as ##x \to \infty##, we can assume that x > 0, but since no information is given about a, the best we can do is to write ##\sqrt{a^2x^2} = |a|x##.
Regarding the limit above, use the fact that ##\lim AB = \lim A \cdot \lim B##, provided that both limits exist.
So lim B = 0
Lim A = ∞
LimA.LimB = ∞ * 0 which is indeterminate.
I suspect the problem should have been ##\displaystyle\ \lim_{x\to\infty} (\sqrt{a^2x^2 +bx + c\ } -ax) \ ## or similar.
Multiply & divide by the complex conjugate ( ← Added in quick Edit. Mark beat me to it!)
You're right. A trick that often works in cases like this is to multiply by the conjugate over itself. (IOW, multiply by 1 in a certain form).
Going back to the original problem, ## \lim_{x\to\infty} (\sqrt{a^2x^2 +bx + x} -ax)##, try multiplying by ##\frac{\sqrt{a^2x^2 +bx + x} + ax}{\sqrt{a^2x^2 +bx + x} + ax}##
BTW, are you sure about the quantity in the radical? It seems odd to me to have bx + x in there. I'm wondering if the last two terms should be bx + c. Just checking.
Edit: Sammy beat me to it.
Raghav Gupta said:
I get
No, you cannot say that. We have
[tex]\sqrt{a^2 x^2 + bx + x} = |a x| \left( 1 + \frac{b+1}{a^2} \frac{1}{x} \right)^{1/2} - ax \doteq |a|x \left(1 + \frac{b+1}{2a^2} \frac{1}{x} \right) -ax\\<br /> = |a|x - ax + |a| \frac{b+1}{2a^2}.[/tex]
for large ##x > 0##. Again, I ask: what do you get if ##a > 0##? What do you get if ##a < 0##?
Note added in edit: it looks like one of your choices is correct IF a > 0 AND you mean bx + c inside the square root, instead of the bx + x that you wrote.
Raghav Gupta said:
So lim B = 0
Lim A = ∞
Note added in edit: it looks like one of your choices is correct IF a > 0 AND you mean bx + c inside the square root, instead of the bx + b that you wrote.
In the radical there is bx + x term as I have typed earlier. It is sure.
When I do the multiplying and dividing by conjugate and do some solving I get the the answer (b+1)/2a
for a>0. For a<0 it is undefined.
For bx + c term I am getting answer b/2a for a>0
Why wolfram is showing something else?
It is almost surely a typo -- maybe not your typo, but somebody's typo. (I looked at my keyboard, and right beside the "x" key is the "c" key.)
Tell Wolfram that a>0, (place ", a>0 " immediately after the rest of your input to Wolfram.)
Getting not the result, see
wolfram1
And
wolfram2
wolfram1
And
wolfram2
The following worked for me: Wolfman .
, a>0
You need the comma .
Got it, thanks to all of you- ehild, Sammy,Ray and @Mark44 ( I don't know if it was a coincidence or you are really a fan of Mark 44 ?)
Purely a coincidence - I had never heard of Mark 44 before.
Neither have I
Mark 44 seems a fairly modern contraption. Mark44 is probably in existence since 1944 !
Mark44 said:
Correctamundo!
I thought maybe Mark44 was 22 times Mark Twain.
