Evaluating CDF of a Random Variable with Exponential Components
  • Context: High School
  • Thread starter Thread starter EngWiPy
    Cdf
12 replies · 3K views
EngWiPy
Hello all,
I have the following random variable ##X=\frac{a_1}{a_2+1}##, where ##a_i=b_i/c_i##, where ##b_i## and ##c_i## are exponential random variables with mean 1. I need to evaluate the CDF of ##X## as
[tex]F_X(x)=Pr\left[X\leq x\right]=Pr\left[\frac{a_1}{a_2+1}\leq x\right]=\int_0^{\infty}Pr\left[a_1\leq x(a_2+1)\right]f_{a_2}(a_2)\,da_2[/tex]
I found the CDF and PDF of ##a_i## as ##F_{a_i}(x)=1-\frac{1}{1+x}## and ##f_{a_i}(x)=\frac{1}{(1+x)^2}##. My fist question is: are the limits of the integral above correct?
Thanks
micromass said:
You can't solve this unless you know the joint distributions of the variables.
All random variables are independent. I forgot to mention this.
OK. I agree with the pdf and cfd of the ##a_i## then. But ##a_2## is the name of a function. So you can't use that as integration variable.
Is this OK?
F_X(x)=Pr\left[X\leq x\right]=Pr\left[\frac{a_1}{a_2+1}\leq x\right]=\int_0^{\infty}Pr\left[a_1\leq x(\beta+1)\right]f_{a_2}(\beta)\,d\beta
S_David said:
Is this OK?
I don't see how that follows. I would agree with
F_X(x)=Pr\left[X\leq x\right]=Pr\left[\frac{a_1}{a_2+1}\leq x\right]=\int_0^{\infty}Pr\left[a_1\leq x(a_2+1)\right]f_{a_2}(\beta)\,d\beta
But I don't see why the ##a_2## can be a ##\beta##.
OK, thanks. So, I guess this means that the limits are correct. I would like to proceed to evaluate the integral, because I did on my papers, and got a final expression, but evaluating it using software gave me values that aren't correct.
micromass said:
The integral you posted is not correct. I don't see where it comes from at all.
$$Pr\left[a_1\leq x(a_2+1)\right]=\int_{a_2}Pr\left[\left. a_1\leq x(\beta+1)\right| a_2=\beta\right]f_{a_2}(\beta)\,d\beta$$
To my undertsnading, since ##a_2## is a random variable too, we average over all the values of ##a_2##. For the sake of argument, how would you find the CDF above?
I would solve it by evaluating the following integral:
[tex]\mathbb{P}\{a_1\leq x(a_2 + 1)\} = \int_0^{+\infty} \int_0^{x(\beta_2 + 1)} f_{a_1}(\beta_1)f_{a_2}(\beta_2) d\beta_1 d\beta_2[/tex]
I think our disagreement is only about using symbols. Your evaluation can be re-written as
\mathbb{P}\{a_1\leq x(a_2 + 1)\} = \int_0^{+\infty} \underbrace{\left[\int_0^{x(\beta_2 + 1)} f_{a_1}(\beta_1)\,d\beta_1\right]}_{F_{a_1}\left(x[\beta_2+1]\right)=Pr\left[a_1\leq x(\beta_2+1)\right]} f_{a_2}(\beta_2) d\beta_2
which is effectively the same as I did in the the previous posts.
Are we on the same page now?
Substituting the CDF of ##a_1## and the PDF of ##a_2## in the integral yields
$$F_X(x)=\int_0^{\infty}\left[1-\frac{1}{1+x(\beta+1)}\right]\frac{1}{(1+\beta)^2}\,d\beta=1-\frac{1}{x}\int_0^{\infty}\frac{1}{\beta+\left(1+\frac{1}{x}\right)}\frac{1}{(1+\beta)^2}\,d\beta$$
Then I used the integral formula attached from the table of integrals. Is there anything wrong in my work?
Using the integration formula attached yields to:
[tex]F_X(x)=1-\frac{1}{x}B(1,2)_2F_1(2,1;3;1-\left(1+\frac{1}{x}\right))[/tex]
where ##B(.,.)## is the Beta function, and ##_2F_1## is the Gauss Hypergeometric function. The constants in the integral attached are: ##\nu=1##, ##\beta=1## which implies that ##\mu=2##, and ##\gamma=1+\frac{1}{x}## which implies ##\rho=1##. I checked the conditions, and they are satisfied. However, the result of ##F_X(x)## must be in ##[0,\,1]## which isn't the case when I evaluate it in Mathematica. Why? I appreciate any help.
