Evaluating Limit using Maclaurin series
7 replies · 12K views · last reply
BrownianMan
Limit expression: lim as x approaches 0 of (sin x - x) divided by (2e^x - 2 - 2x - x^2).
This is an example given in my textbook. The final answer is 1/6. I know that sinx and 2e^x have to be replaced with their corresponding Maclaurin series. However, I'm having trouble understanding the steps they took to get the limit in a form in which it could be evaluated by substituting x=0.
If anyone could help, I'd appreciate it!
  • Limit as x approaches 0 of (sin x - x) divided by (2e^x - 2 - 2x - x^2).
Substitute the series. What's the lowest power of x that doesn't cancel in numerator and denominator? Cancel it as a common factor.
The limit is actually equal to -1/2, not 1/6, so if you think you don't understand it because you're getting the "wrong" answer, that might be why.
I concur with vela on the value of the limit.
If you don't actually have to use Maclaurin series to evaluate this limit, it can be found by applying L'Hopital's Rule a few times.
Yes, the answer is -1/2!
However, I'm still having some problems.
Limit as x approaches 0 of a ratio of two series: numerator sum from k=1 to infinity of (-1)^k x^(2k+6)/(2k+1)! equals limit of (-x^3/6 + x^5 sum from k=2 of (-1)^k x^(2k-4)/(2k+1)!) over (2x^3/6 + x^4 sum from k=4 of 2x^(2k-4)/k!).
I'm not understanding how they went from the limit on the left to the one on the right.
  • Limit as x approaches 0 of a ratio of two series: numerator sum from k=1 of (-1)^k x^(2k+1)/(2k+1)! over denominator sum from k=3 of 2x^k/k!, equals limit as x approaches 0 of (-x^3/6 + x^5 sum from k=2 of (-1)^k x^(2k+1)/(2k+1)!) over (2x^3/6 + x^4 sum from k=4 of 2x^(k-4)/k!).
    2k+1&space;\right&space;)!}}{\frac{2x^3}{6}+x^4\sum_{k=4}^{\infty}\frac{2x^{k-4}}{k!}}.gif
Don't write sin(x) and 2ex as summations. Instead, write sin(x) as x - x3/3! + x5/5! -+ ...
and write 2ex as 2(1 + x + x2/2! + x3/3! + ...)
They just wrote the first term of the series explicitly and then factored out the common power of x from the remaining terms. It's easier to see what's going on in this type of problems if you just write out the series like Mark44 suggested.
