Evaporation of Water: Error in Formula?
The discussion centers on the calculation of water evaporation rates using various equations, specifically the one from engineeringtoolbox.com. The user identifies potential errors in the provided formula, particularly regarding unit conversions that lead to inflated evaporation rates. An alternative equation, M-dot = (A)(42.6 + 37.6V)(Pw - Pa)/Hv, is suggested, but it also yields unrealistic evaporation rates. The conversation highlights the importance of accurate vapor pressure calculations and the need for reliable sources when determining evaporation rates.
  • Understanding of evaporation coefficients and their calculations
  • Familiarity with vapor pressure concepts and calculations
  • Basic knowledge of fluid dynamics and heat transfer principles
  • Proficiency in Visual Basic for implementing evaporation calculations
  • Research the accurate calculation of saturation vapor pressure using temperature and relative humidity
  • Explore the effects of air velocity on evaporation rates in different environmental conditions
  • Learn about the latent heat of vaporization and its impact on evaporation calculations
  • Investigate alternative methods for measuring evaporation rates in outdoor pools
Engineers, environmental scientists, pool maintenance professionals, and anyone involved in calculating or managing water evaporation rates.
t3sseract
I am trying to calculate the rate (g/m2) of water evaporation given Temperature, Humidity, Air Speed, elevation.
The best source of an equation for this I have found is from engineeringtoolbox.com, but I have found a possible error in their calculation. (I am in a far off land with no access to real textbooks)
The equation:
g = Θ A (xs - x) (1)
where
g = amount of evaporated water (kg/h)
Θ = (25 + 19 v) = evaporation coefficient (kg/m2h)
However, later on the example switches air speed units:
g = ( 25 + 19 (0.5 (m/s)) ) ( 25 (m) 20 (m) ) ( 0,019826 (kg/kg) - 0.0115 (kg/kg)) / 3600
= 0.04 kg/s
When I use this equation with m/s and kg/s, I get an inflated evaporation rate (their example alone provides and incredible evaporation rate for a pool).
Can anyone give me a confirmation of this equation?
Is there a more recommended equation for calculating evaporation(and a source)?
Thank you
:3
This should work.
M-dot= (A)(42.6+37.6V)(Pw-Pa)/Hv
where
m-dot= evaporation rate, kg/hr
A= surface area, m^2
V= air velocity over water surface, m/s
Pw= saturation vapor pressure at water temperature, mm Hg
Ps= saturation vapor pressure of air dew point, mm Hg
Hv= latent heat of vaporization of water at pool temperature, about 2270 KJ/Kg
This equation is also giving me inflated evaporation rates:
Using:
A = 9m2
V = 0.5m/s
Pw (at 25 deg. C) = 11.76 mmHg
Ps (at 50% RH) = 23.53 mmHg
Gives:
m-dot = 2.84 kg/hr
At this rate my pool will empty almost as fast as I can fill it.
I am using the following equations for computing the Pressures (in Pa, and in visualbasic)
Public Function Vap_Pres_Sat(TempK As Double) As Double
Vap_Pres_Sat = 22105649.25 * Exp((-27405.526 + 97.5413 * TempK + -0.146244 * TempK ^ 2 + 0.00012558 * TempK ^ 3 + -0.000000048502 * TempK ^ 4) / (4.34903 * TempK - 0.0039381 * TempK ^ 2))
End Function
Public Function Vap_Pres(TempK As Double, RH As Double) As Double
Vap_Pres = Vap_Pres_Sat(TempK) * RH
End Function
Pw@25 C = 23.71 mmHG
Ps@ 18 C = 15.46 mmHG ( 25 C air temp, 50% RH)
m-dot= 2 KG/hr, that is about .0022 cm/hr drop in water level for a 9 m^2 surface area
For a vapor pressure calculator goto:
www.csgnetwork.com/vaporpressurecalc.html
To review evaporation rate information goto:
"Measurement and analysis of Evaporation from an inactive outdoor swimming pool"
www.p2pays.org/ref/19/18985.pdf
I don't have a formula for you, however, I can tell you from experience that you can expect no more than a 1/2 inch of evaporation, for a full day, in the hottest of weather. You can expect increased evaporation if you are in a very windy area. If you think your evaporating too much water, turn the pool off overnight, if you've lost water overnite chances are you have a leak.
See
http://www.rlmartin.com/rspec/whatis/equations.htm
Bob S
  • · Replies 16 ·
  • · Replies 20 ·
11K
