Example of cover (of a set) having finite sub-covers in collection.
  • Context: Graduate
  • Thread starter Thread starter experimentX
    Example Finite Set
The discussion revolves around the concept of compactness in topology, specifically focusing on examples of covers and finite sub-covers. Participants explore the implications of compactness for different sets, such as (0,1) and [0,1], and seek to clarify the conditions under which a set is considered compact.
  • Some participants express confusion about the concept of compactness and request examples of covers that contain finite sub-covers.
  • One participant asserts that (0,1) is not compact and suggests that adding the interval (0,1) to a cover does not provide a meaningful example of compactness.
  • Another participant questions how to demonstrate that compact sets have finite sub-covers if examples cannot be constructed, despite understanding the theoretical proof.
  • It is noted that in R^n, compactness is equivalent to being closed and bounded, referencing the Heine-Borel theorem as a potential avenue for understanding.
  • One participant provides an example of a closed and bounded set, X, and outlines a proof of its compactness using the definition of compactness.
  • There is a discussion about the implications of certain covers for the sets (0,1) and [0,1], with some participants arguing that certain covers do not demonstrate compactness for (0,1) despite covering [0,1].
  • Concerns are raised about the notation and clarity of the proposed sets and covers, with suggestions for more precise definitions.
Participants do not reach a consensus on the examples of covers and finite sub-covers, with multiple competing views on the nature of compactness and the validity of the examples provided. The discussion remains unresolved regarding the specific examples that illustrate the concept of compactness.
Limitations include the dependence on definitions of compactness and the varying interpretations of covers and sub-covers. Some mathematical steps and assumptions remain unresolved, particularly regarding the relationship between different sets and their compactness properties.
experimentX
I think I am not understanding the concept of compactness. Can anyone give me an example of a cover that contains finite sub-covers? for example:- G = {S1,S2, ... }, Sn={(1/n,2/n): n ≥ 2} is an example of cover of set (0,1) but it is an infinite collection.
As you have shown, (0,1) is not compact.
It is not interesting to have some finite subcover - just add T=(0,1) to your list, and there is a finite subcover (any finite subset with T). Compactness means that every cover has a finite subcover. For compact sets, you cannot create examples like the one on your post.
Then how could we say that cover of compact sets have finite sub-cover if we can't construct them. Shouldn't there be at least one example? I understand the proof given in my book but I can't visualize it.
It depends. In R^n , there is a result that compact is equivalent to being closed and bounded. Maybe if you go over this theorem (Heine-Borel) , you can see how being closed and bounded implies that every cover has a finite subcover. In metric spaces there are related results you can use, like that every sequence has a convergent subsequence. So you can try to see the connection between these two by going over the proofs. But I don't know how to do this more generally.
The set of all open intervals with length 1 is an open cover of the closed interval [0,1]. The set ##\left\{\left(\frac{-1}{3},\frac{2}{3}\right),\left(\frac{1}{3},\frac{4}{3}\right)\right\}## is a finite sub-cover.
but this also covers (0,1), this would also be a finite sub cover of (0,1) making (0,1) compact. What I am asking is an example of sub covers of [0,1] that makes [0,1] compact while it does not make (0,1) compact
It covers (0,1), but it doesn't make (0,1) compact (or [0,1] for that matter...I mean, [0,1] is compact, but it takes more than this to prove it). A set is compact if every open cover has a finite subcover. I only mentioned one open cover that has an open subcover.
Also, every cover of [0,1] will of course also cover (0,1).
So I don't understand what you want. I'm not even sure I understand what you mean by an "example".
The set X= {0, 1, 1/2, 1/3, ..., 1/n,...}, that is, the set containing the sequence 1/n for n any positive integer and 0, is both closed (because it contains the limit of the sequence) and bounded (it obviously lies in [0, 1]) and so, as a subset of the real numbers, is compact. To prove that directly from the definition of "compact" I would do the following:
Suppose [itex]\{U_n\}[/itex] is a open cover for X. Then 0 is in one of those sets- rename it U0. Since U0 is open, there exist some r such that the interval (-r, r) is a subset of U0. There exis some integer N, such that N> 1/r and so 1/N< r. That means that for all [itex]n\ge N[/itex], 1/n< r and so is contained in U0. We then choose a set from the open cover containing 1/n for every n< N, a finite number of sets, and those, together with U0 form a finite sub-cover.
Notice that is essential that 0 be in this set. The set {1, 1/2, ..., 1/n, ...} itself is bounded but not closed and so not compact. For every integer n, Let Un be the interval from (2n+1)/(2n(n+1)) to (2n-1)/(2n(n-1)). The point of that is that (2n+1)/(2n(n+1)) is exactly half way between 1/n and 1/(n+1) while (2n-1)/(2n(n-1)) is exactly half way between 1/n and 1/(n-1). That is, that interval includes ONLY the point 1/n from this set. Since each set in the cover includes only one point of the set, we have to have all of them to cover the set- and we certainly can't reduce to a finite cover.
would this set be finite sub-cover of [0, 1] Sn={(1/n -ε, 2/n + ε): n ≥ 2} ? Choosing n > N ≥ 1/ε where ε > 0 would make it cover [0, 1]?
The set ##\{(1/n-\varepsilon,2/n+\varepsilon):n\geq 2\}## has infinitely many members. n is just a dummy variable. The set is the same if you use another dummy variable. So it doesn't really make sense to call the set Sn. Also, (this is a bit nitpicky) the notation should specify that n is an integer.
I would just call the set S. It's an open cover of both [0,1] and (0,1). The subset of S that's defined by the condition n≥N contains all but a finite number of members of S. It's another open cover of both [0,1] and (0,1), and it's not finite.
  • · Replies 24 ·
