Expectation of ratio of 2 independent random variables ?
The expectation of the ratio of two independent random variables, E[x/y], does not equal E[x] / E[y]. Instead, it holds that E[x/y] = E[x] * E[1/y], but E[1/y] is not equal to 1/E[y]. For instance, if y is a uniform random variable between 0 and 1, E[1/y] diverges to infinity. Even when y is restricted to a range like 1 to 2, E[1/y] yields a value that does not equal the reciprocal of E[y]. This discrepancy is explained by Jensen's inequality, which indicates that E[1/y] is always greater than 1/E[y] when y has a finite expectation.
nikozm
Hi,
i was wondering if the following is valid:
E[x/y] = E[x] / E[y], given that {x,y} are non-negative and independent random variables and E[.] stands for the expectation operator.
Thanks
No, this is not true. It is true that E[x/y] = E[x]*E[1/y] but it is not true that E[1/y] = 1/E[y]. For example if y is a uniform random variable taking values between 0 and 1,
E[1/y] = \int_{0}^{1} \frac{1}{y} dy = \infty.
Even if you restrict yourself away from zero to avoid stupid division problems, if y is a uniform random variable between 1 and 2,
E[1/y] = \int_{1}^{2} \frac{1}{y} dy = \ln(2) \neq 1.5
More can be said. Given y is >0-valued with finite expectation, you will always have \mathbb E\left[\dfrac1y\right] > \dfrac1{\mathbb E[y]}, except in the extreme case that y exhibits no randomness. This follows from Jensen's inequality, since the function t\mapsto \dfrac1t is strictly convex on (0,\infty).
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
  • · Replies 30 ·
